Modifying the stock airbox - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 07-09-2012, 08:17 PM Thread Starter
new kawi rider's Avatar
Have a question for all you mechanical incline folks out there. I was thinking of waterjetting a cool design in the left cover of the airbox where the filter is. Not only would it look cool it would get more air I would think. My question is if I cut a designed into like the circle part of the cover would that keep the k and n filter from sealing inside there. Thanks for the info in advance!
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #2 of 3 (permalink) Old 07-09-2012, 09:08 PM
RACNRAY's Avatar
It will NOT cause a sealing problem qith the filter.
Back in June 2011 during the first dyno session with my Vaquero i completely cut out the smaller circular area of the emblem on the left side air box lid and LOST 5 h.p. due to the air "choking" as it tried to pass thru the connector channel between the 2 air boxes. During the dyno run i could feel the air coming OUT of the hole due to intake reversion. I did a couple of runs to make sure of the accuracy, and sure enuff there was a MAJOR loss of power. I then did 3 more runs, first run taping off 1/3 of the hole, power went up, 2nd run taping off 2/3 of the hole, power came up again but still below the best run with an un-cut a/box lid. then the 3rd run with the hole completly taped shut, power back to stock.
If you are gonna cut a design into that area the back side of the air box lid would have to be sealed so no air can go thru the design you have cut .I have done this on skoots before and glued chrome or carbon fibre pattern material on the inside, you can even use a piece of material in a color to contrast and compliment your skoot.
The extra air that a replacement k&n filter supplies to the engine does not cause the air to "choke", if you want more air thus more power it will have to be accomplished with a Big Air Kit.
RACNRAY
RACNRAY is offline
post #3 of 3 (permalink) Old 07-09-2012, 09:13 PM Thread Starter
thanks
Thanks ray thats the info I was looking for. So that will not be happening now! I reckon I am not looking for more power just better mpg with a map in the pcv. I was thinking that adding more air might help that problem.
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
Modifying Stock Exhaust Tracks650 Vulcan 650 S 222 09-08-2019 10:14 AM
Modifying stock tailight billv Vulcan 650 S 13 06-17-2018 06:29 PM
Modifying stock exhaust? jrubicon Vulcan 650 S 1 07-11-2015 04:58 PM
modifying stock exhaust bobby c The Bobber, Ratbike, Chopper Connection! 3 04-18-2014 02:37 AM
Modifying my VN1500 Classic Kauzi Vulcan 1500 0 12-03-2010 07:49 PM
