Performance Machine Air Cleaner - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-22-2012, 08:06 PM Thread Starter
BOTM Winner, June 2013
Hey guys, need a little help. I just purchased the performance machine super gas air cleaner through Twin Toyz, but it arrived with no instructions. Does anyone have experience with this air cleaner, if so please help. Thanks.
Law369 is offline
post #2 of 4 (permalink) Old 06-22-2012, 09:05 PM
davidsheek's Avatar
Did you call PM to see if they normanly send instructions?
They should be able to email you a PDF file if it.
davidsheek is offline
post #3 of 4 (permalink) Old 06-22-2012, 09:40 PM
BrucerZX14's Avatar
Smile
I have the same air filter kit. First you need to remove all the stock air box stuff. Both sides and the cross over tube between the cylinders. You need to disconnect the air temp sensor to remove the right side.
Then remove the front plate on the throttle bodies. 5 screws if I remember correctly. It has rubber velocity stacks on it. You don't re-use any of it. The kit comes with longer screws.
Remove the air temp sensor from the the stock air box. It needs to be mounted in the backplate of the new PM backplate. You'll see the hole for it.
Put some RTV around the mount area to seal the pieces to prevent air leaks. Mount the new backplate on the throttle bodies using the longer screws.
Connect the air temp sensor. I had to reroute the air temp connector over some wires for it to reach the new backplate once it was installed.
There are 5 long chrome allenhead screws and 5 chrome stand-offs. These, with the front ring, hold the air filter on. Install it.
You'll need to plug the AIS hose that was on the stock air box. Use what you can to plug it.
You'll also have to find a small filter to connect to the crankcase vent hose. I found one at Pep Boys for about $10.
Hope this helps. If not, PM me and I'll see what I can do to help more.
2010 Voyager
Roaring Twinz Air Kit
Thunder Manufacturing dress-up plate
VN1500 kickstand
Chrome bling on passenger floorboards
Rockford Fosgate Amplifer
Polk Audio/Kicker speakers
Kawasaki CB radio
Rear speaker kit
Vance & Hines Twin Slash slip-ons
Power Commander V
Portable XM radio thru AUX
Marvellas trailer hitch
Lower bag rails
Kuryakyn Tour-tech cruise peg mounts
Kuryakyn black ISO grips w/bar-end weight & red trim
BrucerZX14 is offline
post #4 of 4 (permalink) Old 06-22-2012, 09:57 PM Thread Starter
You'll need to plug the AIS hose that was on the stock air box. Use what you canm to plug it.
Thanks a lot, I should be ok with this information.
Law369 is offline
Respect the Machine Alansire New Riders 7 02-14-2014 04:27 PM
Lean machine DANAD Vulcan 1500 2 04-09-2013 11:13 AM
The Ultimate Home COIL winding Machine bikeman2011 Vulcan 900 0 03-09-2011 04:28 PM
Tire Changeing Machine optomatt Vulcan 2000 4 11-27-2010 01:29 PM
