Fixed a few rattles in the fairing - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 06-21-2012, 04:16 AM Thread Starter
Dozrtravlin's Avatar
Hit a big bump a while back followed by quite a bit of water damaged road. End result was a few rattles from the fairing.
So I pulled the fairing off, really easy providing you do the lowers first. I found every screw and bolt apart from the main mounting bold had loosened anything from 3/4 to 1 1/2 turns. This included every screw in the radio housing and the instrument panel. I also found a large multi pin plug sitting against the fairing support that rattled when bumped. I added a little foam to all areas where different components clipped of screwed together . End result no obvious rattles.
So if you have a few rattles it's worth a couple of hours to fix them
2009 Voyager, "Battle Star"
SageBrush Bib,
LED's around Headlight,
Chrome cup holders,
Marvellas passenger and rider highway pegs,
Grasshoper backrest,
Kawasaki Gel seats,
Grey Sheepskin Seat covers,
Kawasaki Rear Speakers,
Ipod Kit,
H.D. trunk rack,
Chrome passenger board covers,
Chrome Engine plate,
Door Controller,
Fog Lights wired to High Beam on/off.
Speedo Healer, Backoff Brake Module
KAM's heat kit
BLue Knights BKAUS11 and
BlueLiners Australia
Ride with Pride
Dozrtravlin is offline
post #2 of 3 (permalink) Old 06-21-2012, 09:53 PM
Sometimes you have to go where no man has gone before!And hope you can get all back together!Even my 2012 rattles a bit.May have to go explore.
ta-kid is offline
post #3 of 3 (permalink) Old 06-21-2012, 10:35 PM Thread Starter
Really is easy if you follow Kawasaki methods I think mot of my rattles came from the top bit of plastic on the dash (the one with the two screws, and from the large plug floating around on the harness banging against the frame or inner fairing after it came loose.
SageBrush Bib,
Chrome cup holders,
Kawasaki Gel seats,
Ipod Kit,
H.D. trunk rack,
Door Controller,
KAM's heat kit
Ride with Pride
Rattles @ ~2000rpm ChevelleSSLS6 Vulcan 900 3 05-30-2013 06:11 PM
rattles........... cudaboy Engine Work 1 04-17-2013 09:33 AM
voyager rattles under windsheild randysvoyager New Member Introductions 6 03-16-2012 03:57 PM
How do you find and nuke rattles? MjrNuT Vulcan 800 2 11-26-2009 04:58 AM
No Spark 2000 Nomad Fixed bcycle Vulcan 1500 0 02-21-2009 06:08 PM
