stock risers - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 06-18-2012, 11:56 PM Thread Starter
new kawi rider's Avatar
stock risers
I tried to putthe scoot works riser on amd wow thw cables are way to short! I am trying to put the stock risers back on now and when I took them apart I didnt notice wich way the arrows were pointing! Any one know for sure wich way the arrows are supposed to point on what riser? Thanks
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #2 of 13 (permalink) Old 06-19-2012, 12:41 AM
davidsheek's Avatar
Where are the arrows on the riser? I'll look in manual.
davidsheek is offline
post #3 of 13 (permalink) Old 06-19-2012, 12:56 AM
davidsheek's Avatar
The shop manual calls them handlebar holders. I read the whole paragraph where it talks about installing the holders with the bolts and nuts. It says nothing about aligning anything. Just gives a torque value for the nuts. Arrows usually point forward. Honestly I'm sure they're both identical. The manual would have said something if they had to go on a certain way.
post #4 of 13 (permalink) Old 06-19-2012, 09:17 AM Thread Starter
risers
The bolt holes in the risers are offset and the have 1 arrow pure riser. Not sure if the arrow should point out on in. I downloaded the shop manual and as you said it says nothing about the arrows.
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
post #5 of 13 (permalink) Old 06-19-2012, 03:55 PM
Bubba in TX's Avatar
I do not see any "arrow" but risers have a correct orientation which includes the top clamp. Most have a small dot impressed on the top clamp. This is normally the bottom (towards tank). They are designed to have the forward bolt tightened first (one on fairing end) to spec torque, and then the lower bolt closes the clamp and does the compressing and will have a small gap on the end. THE top end of the clamp should not have any gap. The lower and upper part of the riser should be touching, (or closed).
Sometimes when you have the top clamp parts wrong you can snap the upper clamp part in two when you torque it down.
As long as you have all the markings the same direction you should be good. An all of my Yamaha's ALL the markings face to the tank.
Like I said I do not see any marks on the Voyager riser. The only one I see is the very edge of the alignment punch mark on the handlebar at the outside edge of the left riser. (the handlebar centering mark)
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #6 of 13 (permalink) Old 06-19-2012, 04:12 PM Thread Starter
arrows
So your saying the bottom part of the risers dont have arrows on them? Mine sure do.
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
post #7 of 13 (permalink) Old 06-19-2012, 05:19 PM
Greystone's Avatar
How about a pic?
2011 900 Classic SE
"Those who know how to win are far more numerous than those who know how to make proper use of their victories." - Polybius
Greystone is offline
post #8 of 13 (permalink) Old 06-19-2012, 05:24 PM
If mine has arrows I do not see them. The only thing I have done with my bars is to raise them as high as they can go without hitting the fairing.
ALSO did you try re-routing your cables/clutch/brake line?
Bubba in TX
I actually ride
WRAP your pipes....
U.S.A.F. Retired
Nye County Nevada
post #9 of 13 (permalink) Old 06-19-2012, 08:27 PM
Top K's Avatar
You don't have to give up so easily on the Riser's - just remove the Triple Tree and route the shorter cables behind it (that's what I did). There's a thread on here that mentions the size of the stem nut.
'09 Kawasaki Voyager ABS
USMC 77-99
PGR
Band of Brothers USMC MRC
Top K is offline
post #10 of 13 (permalink) Old 06-19-2012, 09:38 PM Thread Starter
phat risers
I took my brake line off and re routed it! Then I bled the front brake! That worked for me. Had a buddy helping me tonight we had them on in bout 20 min without bleeding the front brake. The risers are great took it for a 50 mile ride it was worth the trouble!
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
WTT: Barons Pull-back risers for stock 900 LT Risers crazyriderguy Wanted to buy or trade Items 0 03-18-2017 03:23 PM
1700 grip, seat, risers, 900 turn single bar, risers. mes882 Bike Parts, exhausts, etc. For Sale 6 07-03-2016 12:03 PM
Risers or no risers? Thriller E Vulcan 1600 14 08-12-2012 10:28 PM
Vulcan 900 parts: stock seat, stock pipes, risers, beach bars, pulley, bag supports lilduec Bikes For Sale 15 05-11-2011 09:13 AM
Stock classic handlebar risers needed redknob Vulcan 900 6 05-01-2009 04:56 AM
