Extend the lower vent adjusters - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 06-17-2012, 10:47 AM Thread Starter
raw6464's Avatar
Having short arms I couldn't open/close the lower vents while riding. So I made an extender from 1/2" I.D. tubing, some silicone, wiring split loom (optional) and a couple of end caps also optional. I had the end caps from a left over outdoor table.
CONSTRUCTION:
1. Cut 1/2" I.D. tubing into 2 tubes 4" or 5" long.
2. Squeeze silicone into the tube leaving 1/2" empty at each end of the
tube. I used a dark gray silicone caulking I had. Leaving the 1/2" empty at
each end is to prevent the silicone from oozing out all over the place.
The silicone gives the tube more rigid and glues the tube to the existing handle.
3. Push one end of the tube as far as you can onto the existing vent adjuster
handle. Some of the silicone is going to get pushed out to the open end...
wipe any excess.
4. Wait for the silicone to set then put the split loom over the tube.
5. You'll have to use your imagination for the end caps.
2009 Voyager
2003 Goldwing
raw6464 is offline
post #2 of 5 (permalink) Old 06-17-2012, 03:24 PM
mrjava's Avatar
Does it work for you? then awesome!!
2011 Black Vaquero 1700
Amsoil Oil & Filter
HID 65W headlight
Stebel Horn
RacnRay Throttle Mod
Avon Grips
Cobra FI2000 PowerPro V2
Shorai Battery LFX21A6-BS12
ClearView 16 1/2 windshield
Thunder Airkit 51010
Thunder Throttle body gasket
Scootworks' PhatRisers 1XVB
Michelin Commander II F7R @3250 miles
Progressive 430 rear shocks
Progressive 10-2210 front springs
Chevron, Mobil, Shell 92 octane
mrjava is offline
post #3 of 5 (permalink) Old 06-17-2012, 07:26 PM Thread Starter
raw6464's Avatar
Yes it works... just another modification attributed to the mother of invention getting the bike to fit me
2009 Voyager
2003 Goldwing
raw6464 is offline
post #4 of 5 (permalink) Old 06-17-2012, 09:45 PM
hank43's Avatar
CONSTRUCTION:
wipe any excess.
What a clever idea! I hate having to stop to open the vents, never know how much I want them open etc. Good job!
hank
2009 VV1700 ABS, Champion triked
hank43 is offline
post #5 of 5 (permalink) Old 06-18-2012, 05:39 AM Thread Starter
raw6464's Avatar
Thanks. The split flex and the end cap are for cosmetics only. If the tubing you have has a curve in it from being stored in a loop... all the better... mount the tube with the curving up to better conceal it.
2009 Voyager
2003 Goldwing
raw6464 is offline
Canadian Riders... Chance to extend KPP otter Vulcan 1700 0 05-27-2018 11:44 AM
Extend my windscreen? schlappy95 Vulcan 1700 29 08-20-2017 01:29 PM
Do I extend my windscreen, if so, how? schlappy95 General Vulcan Talk 0 08-02-2017 09:20 PM
extend passenger floor boards lifetooshort Vulcan 1700 4 03-23-2013 10:46 AM
