Belt Noise - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Peg
post #1 of 6 (permalink) Old 07-29-2017, 01:33 PM Thread Starter
Year/Make/Model: 2015 Kawasaki Voyager
Color: Charcole Gray
Belt Noise
Do all of these bikes have belt noise when coasting? Mine sometimes drives me nuts. I have had it adjusted twice but it has never been quit when coasting.
sailorman3 is offline
post #2 of 6 (permalink) Old 07-29-2017, 02:30 PM
Year/Make/Model: 2013 Kawasaki 1700 Voyager
Color: Blue/Black
I've got a 2013 Voyager, I haven't noticed any noise from the belt. At times I will do different riding skills exercises in parking lots as well (some at slow speeds). I've never noticed any noise.
Sent from my XT1563 using Tapatalk
schlappy95 is offline
post #3 of 6 (permalink) Old 07-29-2017, 03:46 PM
reggae5's Avatar
Location: Crescent City Fl formerly Key West Fl -Formerly Detroit - Formerly Canada
Year/Make/Model: 2012 Vulcan Classic
Displacement/CC's: 900
Color: Dark Burgundy metal flake
I actually just got my 900 classic back from the shop it was making a rubbing strange sound I could hear when I pushed it in the driveway. Come to find out it was only because the belt became to tight. And on the front sprocket the shaft had no lube at all left on it. Some days you get lucky maybe/hopefully that is all that is wrong with yours?
reggae5 is offline
post #4 of 6 (permalink) Old 07-29-2017, 04:18 PM
Peg
Peg's Avatar
It's generally agreed that Kaw spec is too tight, and most of us have found that loosening the belt to HD tension (I have mine at around 10mm at 10lb) keeps it quiet, and also prevents issues such as pulley wear, belt damage, and in extreme cases output shaft bearing failure.
Sabre-t likes this.
Paul (Peg) Elliott
Peg is offline
post #5 of 6 (permalink) Old 08-04-2017, 10:37 AM
bcusick's Avatar
Year/Make/Model: 2012 1700 Voyager
Color: White / Beige
Mine makes noise on acceleration after a deceleration. I attribute this to the belt walking from one side to the other.
bcusick is offline
post #6 of 6 (permalink) Old 08-04-2017, 01:29 PM
I purchased a new 2016 Voyager March of this year. Belt noise from the start right off dealer lot. Its sad, but I try to avoid taking my bike to the dealer for anything.....even under warranty. After a few weeks of the howling cat sound I decided to investigate. The drive belt was way too tight and also misaligned from the factory. One side ahead of the index mark, the other was behind. I lined up using the index marks and loosened tension slightly. Most of the noise was gone then. After owning eight GoldWings over many years, this belt noise is hard for me to overcome. Most of the time I can zone it out or turn up the mp3 player. I am going to replace the rear tire soon. I plan on cleaning the belt and sprockets and then spraying dry Teflon on the belt. I'm sure it will make the belt quiet and I"ll see how long this lasts. Overall the Voyager is a great bike, but apparently belt noise is common regardless of manufacturer.
08Nomad is offline
Belt Chirp/Dead Horse/Belt Squeal Wild_Bill Vulcan 2000 25 05-29-2019 04:33 PM
** Belt Noise ** SakiRider Vulcan 1700 16 10-17-2010 10:26 AM
Belt noise Silver Shadow Vulcan 900 23 09-16-2010 09:54 PM
Question About Belt Noise BOBKAY Vulcan 900 2 08-31-2010 06:37 PM
Belt noise tf900 Vulcan 900 2 08-16-2009 11:09 AM
