2015 Vaquero - PC-V tuning - gear select - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 1 (permalink) Old 07-18-2017, 01:44 PM Thread Starter
paradiddle's Avatar
Question 2015 Vaquero - PC-V tuning - gear select
I have 2015 Vaquero with Freedom pipes and Roaring Toyz air cleaner. we had put in a Vulcan map 2 years ago to get it running and it ran decent. I didnt want to wait for dyno so I got autotune and had bung welded in RS muff same as stock location. Worked well. For awhile. Then at lower TP and rpm would misfire when heat soaked. Next day I did a remap run and then accepted map and disconnected AT. better but it would still do that bad thing. I contacted Chris at PC and he suggested I do a gear based map. so that each gear would have its own map. Now I don't have a service manual and don't know where to find that gear select wire.
Has anyone done gear select ?
I also bought the DJ POD 300 - nice add on panel to see AFR - and can do map swaps and datalog. I used to work at Roaring Toyz machine shop when we had that magazine Vaquero bike.
Eddie D - Venice Fl.
2015 Vaquero VN1700 ABS
Freedom True Duals Black
Roaring Toyz Air Cleaner
PC - V & AutoTune
Roaring Toyz Floor Boards - Burly Mini Ape hangers
Rockford Fosgate 2ch Punch amp (4) Kicker 5.25 Marine 2 ohm speakers
First place winner - Thunder by the Bay - Metric Touring
all work done at Roaring Toyz.
paradiddle is offline
Power Commander V fuel tuning vs ignition tuning Jchristian1094 Vulcan 1700 5 01-24-2017 09:11 PM
Please help me select the right size tire Lumpy Wheels and Tires 3 07-30-2013 10:37 PM
Kawasaki offering free saddle bags on select cruisers none Vulcan 1700 13 03-02-2011 02:28 PM
Universal Power Adapter - Select/Install IMSnake Vulcan 1600 2 05-12-2010 11:13 PM
