Finally pulled the trigger on the amp/speaker upgrade! - Kawasaki Vulcan Forum : Vulcan Forums
 7Likes
post #1 of 20 (permalink) Old 07-05-2017, 11:22 AM Thread Starter
Color: Orange SE
Thought I'd report back to you all!
I've been wanting to upgrade the factory speakers for a while. I wanted marine grade speakers; those summer deluge's always seem to find me on long trips. With Randy Brewster's adapters, I was able to go with 6.5" Polk speakers; and a 300 watt Rockford Fosgate amp.
First I decided to strip the bike down before proceeding. I decided it would be easier to work on if I just had everything out of the way. Frankly, I think people spend more time and energy trying NOT to just take parts off, than they would if they took parts off. It takes less than 5 minutes to remove the fuel tank on the Vaquero; and I'm sure I would spend more time than that fishing wires under it. So off the tank went:
Of course, the fairing also had to be removed. That's not difficult, but it is a little tedious and time consuming. In the process, I also decided to re-wire my trailer lighting setup while I was at it. So I removed the saddlebags and trim. Because I wanted to run the amp directly to the battery; I wanted to move my trailer lights OFF of the battery. I use an isolator circuit, so I just need a source of 12V power. So I just ran those wires to the accessory leads under the seat. Works just fine.
Amp mounted. I realized what a dolt I was running the power alongside the speaker cables. So I did reroute that afterwards. But that's it! Bolted onto a little bracket, fresh wires running to both speakers.
The factory speakers connect to the stereo via a releasable 'clip'. I wanted to limit the amount of factory wiring I cut. So I took the wire that normally runs down from the speakers to the connector on the bottom side of the fairing. I cut the speaker connections off of that, and soldered it to the amplifiers proprietary high-level input harness. So it all plugs right in and can easily be returned to stock; either by soldering on new speaker connections into that factory lead, or just replacing the factory lead. MUCH easier than if I had cut into the bikes main wiring harness.
Here's a shot of the 6.5" speakers mounted. I struggled to find some speakers whose grille was attractive. My GOAL was that if someone walked up to my bike and didn't know better; they'd think it was stock. Obviously, a Vaquero owner is gonna know those are aftermarket; but I didn't want a crazy "aftermarket" look to it. I think those look pretty good.
And the last step before I buttoned it all up; I mounted a Garmin Zumo 595LM ahead of a trip through the Blue Ridge Parkway in a couple of weeks. The fairing 12v accessory leads give absolutely no slack; but they are a super handy place to run wires for the Zumo. Once the fairing is already off, anyway. Had I not already had the fairing off; I probably would've spliced it in to the wires running to the under-seat 12v accessory leads; that are currently occupied by my trailer light isolator kit. (If you look at the wiring diagram; both accessory leads go to the same fuse; so they're on the same circuit regardless). The trailer lights are LED, and the Zumo draws just 1 amp, so it's no big deal.
Under the fairing, there is a GPS audio connector. You can spend $30 to buy the adapter from Kawasaki; but it's something you could easily make yourself with a soldering gun and a trip to anywhere that sells electronic connectors. I elected not to connect it; choosing instead to use my bluetooth headset exclusively. If I change my mind; I can go into the fairing again. Although it's currently all taped up; there is an audio lead in the fairing for the Zumo, that would just have to be connected to the factory stereo.
All in all; I'm fairly happy with it. It's much louder. Audio quality isn't fantastic; I suspect a lot of that is the factory stereo. The install wasn't too difficult. Unfortunately, it was ME doing the install; so the fairing came off a few times. After buttoning it all up and taking it for a test ride, it became apparent that my headlight wasn't working. So the fairing came off again so the idiot who took it off the first time (me) could plug the headlight back in. Somewhere in THAT process, a windshield nut had come loose; so it had to come off a THIRD time. But other than that, a project well done.
Blue Ridge Parkway; here I come!
Romans5.8 is offline
post #2 of 20 (permalink) Old 07-05-2017, 08:57 PM
Glenn54's Avatar
Year/Make/Model: 2013 Voyager
Color: Blue/Black
I'm sure you're glad to have the project done. And you have a lot of experience taking the fairing off now. Ha. Do you think you'll replace the factory head unit? I'd like to have better speakers but not sure I want to go to the trouble of putting in an amp.
Kawasaki rear speakers
VN 1500 Kickstand
Ipod adapter
Kuryakyn Longhorn Offset Highway Pegs
Garmin 390LM w/TPMS
Glenn54 is offline
post #3 of 20 (permalink) Old 07-05-2017, 09:43 PM Thread Starter
Color: Orange SE
The factory stereo doesn't output a lot of power. I'd strongly recommend putting an amp in. The fairing isn't actually that difficult. It's a little time consuming, but there isn't a single part of it that is technical or hard. 15 minutes and it's off.
I probably won't put an aftermarket radio on. Vanity, really. First off; there's a limited number of receivers available that would check all of the boxes (work with the factory handlebar controls, be marine grade, have a rear USB port to run into the side pocket). And, frankly, just about all aftermarket head units out there just look terrible. I really love the look of my bike and want to preserve it. So it's all about vanity; I don't want to change the "look" of the factory stereo.
post #4 of 20 (permalink) Old 07-07-2017, 06:29 AM
T Gibbs's Avatar
Year/Make/Model: 2012 Vulcan Voyager
Color: Pearl White/ Beige
You getting any rattle from your fairing? Mine rattles and vibrates every time the bass hits since I installed the 6.5" speakers.
2012 1700 Voyager
Cobra Slip Ons
Kuryakyn Grips
Klock Werks Windshield
Mustang Seat with Driver Backrest
Kenwood Stereo
Soundstream Amp
Engineered adapters with 6-1/2"Polk Audio Front Speakers
Kawasaki Rear Speaker Pods with Polk Audio 5-1/4" Speakers
Ivan's Flash
T Gibbs is offline
post #5 of 20 (permalink) Old 07-07-2017, 11:39 AM
Reptilicus's Avatar
Year/Make/Model: 2008 Mean Streak
Displacement/CC's: 1600
Color: Candy Fire Red
Try some Dynamat or similar behind the speakers.
Reptilicus is offline
post #6 of 20 (permalink) Old 07-07-2017, 12:07 PM
T Gibbs's Avatar
I may try putting the speaker buckets back in first. I left them out thinking bigger box =more bass.
T Gibbs is offline
post #7 of 20 (permalink) Old 07-07-2017, 01:27 PM
Reptilicus's Avatar
That's generally true, but with the enclosures you should get more volume without distortion. Especially important when you're on two wheels.
post #8 of 20 (permalink) Old 07-07-2017, 01:32 PM
T Gibbs's Avatar
I may have to crank my amp
Down a bit. It already makes the speakers bottom out on hard hits.
T Gibbs is offline
post #9 of 20 (permalink) Old 07-10-2017, 07:49 AM
T Gibbs's Avatar
I put the buckets in and it made a big difference. Speakers don't sound liker they're bottoming out as much as they did before, and it sounds better.
2012 1700 Voyager
Cobra Slip Ons
Kuryakyn Grips
Kenwood Stereo
Soundstream Amp
Ivan's Flash
T Gibbs is offline
post #10 of 20 (permalink) Old 07-10-2017, 08:37 AM Thread Starter
Color: Orange SE
I folloiwed "ohms law" for setting my amp. My speakers are rated at 100 watts RMS and 2.7ohms. So I plugged those numbers into the formula and found that I should be getting 16.43VAC at the output of the amplifier when the stereo is turned all the way up, playing a test tone (that would mean the amp is outputting 100 watts at 2.7ohms). I set it at about 15.2VAC, which is giving me around 85 watts to the speakers. That's plenty, it's very loud, and it's well within what the speakers can handle; and I don't get the clipping, or any rattling, etc. I do have bass turned down a notch or two to eliminate rattle. Dynamat would help, but I didn't go that route. I might in the future.
SilverT likes this.
Finally pulled the trigger! dustin91 Vulcan 650 S 6 05-01-2016 12:31 AM
Pulled the trigger on a BAK... Finally hockeynut52 Vulcan 1700 38 05-27-2015 02:20 PM
Pulled the Trigger.... Hokey Vulcan 500 22 08-04-2011 12:54 PM
Pulled The Trigger!! tl40plus Vulcan 1600 3 03-18-2010 09:11 AM
Pulled the trigger pasnbyu Vulcan 900 0 12-22-2009 06:55 PM
