Test ride after front end mods and maintenance - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 06-24-2017, 12:57 AM Thread Starter
Sabre-t's Avatar
Color: Red/Black
I have been doing a lot of work on the bike preparing for the VBA Rally in Lake George, NY. I finally finished and the weather cooperated today, so I took a test ride.
Besides just needing scheduled maintenance, I was having 1) too much instability in the front end (not an uncommon complaint) 2) some squealing from the front brakes 3) a sort of ratcheting sound from the rear end at slow speeds.
The fork oil needed to be replaced, so I decided to go with a higher weight oil and while I had the forks off, replace the steering stem and wheel bearings (All Balls) and add Garry's fork brace (google "Garry's fork brace", or search this forum or the VBA forum for the same). What a DIFFERENCE! I can't say how much was the oil and how much was the brace, but in my limited experience, changing the fork oil would not take out the wallowing (for lack of a better word) in the front end that I'm pretty sure is caused by flexing of the forks. The brace really stabilized the bike going thru curves or when doing an aggressive swerve in a way that I do not believe a fork oil change alone would. I'll try to remember to take and post a pic of the brace tomorrow. The heavier fork oil stiffened up the mushy front end. Much smoother ride and the front tire rides much better over rough pavement in curves. I went with Motul Maxima 15w oil. Not too stiff and not mushy at all now.
There was a very tiny bit of play in the front wheel, which is gone with the new bearings. The OEM stem bearings were in good shape, good being a relative term for such cheap bearings, so changing the steering stem bearings was mainly for peace of mind. I made the tool below from a 36mm axle socket to torque the steering stem nut. $20 at O'Reily's, and Dremeled with cutting and grinding disks. Since it was an axle socket, it was deep enough that I didn't have to take any material out of the neck to accommodate the stem.
While I had the front end apart, I checked the front brakes. I also did the runout on the rim, the runout and thickness on the disks, and deglazed the disks. When I examined the calipers, I found that I had a very sluggish piston in each caliper, which explains the squeal, so I rebuilt both calipers. I changed the pads (sintered), too. Now the squeal is gone. I also rebuilt the rear caliper. The pistons were a little sluggish there, too. Now, no more clicking.
I changed the front and rear brake fluid and the clutch fluid. Before changing the clutch fluid, I took the slave cylinder off and cleaned it out and cleaned the piston. It is amazing how dirty it was. I had seen a post either here or on the VBA forum about how nasty they get and start sticking. Thanks to whoever posted that. I would never have thought of cleaning it before the seal change was due. I cleaned and lubed the rod, too, as well as cleaning out a lot of junk that was in the cavity and seems to be what gunks the slave unit up. Anyway, the clutch fluid was filthy. Quite a bit of particulate residue in the reservoir. I flushed the line with a good bit of brake fluid from a previously opened bottle, then with new before doing the final bleed.
All this and only one bolt left over! It's obviously a bolt off the fairing, but I can't figure out which one I left off. Doesn't seem to be causing any problems or rattles, so I'll hang on to it until the next time I take the fairing off.
I'm going to flush the system and change the coolant and do an oil change before I leave for NY. This project has taken too much time with all the parts I had to order after I started and all of the other distractions (like a broken tooth and having to replace the entire water delivery line to the house, $$ ). I need some saddle time! I'll take the back end apart and do checks and bearing changes after I get back.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #2 of 3 (permalink) Old 06-24-2017, 07:03 AM
CarGuy's Avatar
Year/Make/Model: 2014 Nomad ABS
Color: Black/White
Sabre-T, that's a real good summary (with detail) of your project. I'm curious... how many miles on your bike, how many miles/time since your last brake and clutch fluid change? I'm getting ready to do mine in a couple of weeks. When I changed the brake fluid the first time on my last bike, a 900LT, the fluid was really dirty, but when I did subsequent changes it was clean. I'll also be looking into that brace. Thanks for posting!
Go for the ride!
2014 Kawasaki 1700 Nomad ABS
2008 Kawasaki 900 Classic LT (sold 2015 42k miles)
1975 Kawasaki KZ400 (sold ~1985)
1970 Suzuki TS250 Scrambler (stolen 1971)
1968 Bridgestone 200 MKII RS (sold 1970)
Patriot Guard Rider
USN 1971-75
CarGuy is online now
post #3 of 3 (permalink) Old 06-24-2017, 04:19 PM Thread Starter
Sabre-t's Avatar
Color: Red/Black
Thanks!
Just shy of 22k miles on the bike. I bought it at 15.5K, just over 2 years ago. The dealer I bought it from said the PO had them do all the service on the bike including the 15k service. So, if that is true, both the clutch and brake fluids should have been changed then. The brake fluid didn't look bad for the time and miles, it was just the clutch fluid that was nasty.
Sorry folks, no pics of the brace today, but if you google as noted in my first post, you can find pics of what it looks like. Mine looks just the same, but not powder coated as some are.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
Harsh/stiff front end ride andyvh1959 Vulcan 1600 5 07-31-2018 10:24 AM
Top end power increase mods rmb0513 Engine Work 5 07-13-2017 12:10 PM
Troubleshooting Front End Vibes After Tire Change VulcanDan61 Vulcan 1700 20 10-07-2016 09:25 PM
Mods and Improvements after thoughts! Sidewalkman Vulcan 1600 2 04-04-2014 12:37 PM
Next maintenance after 3000 miles Aleco Vulcan 900 16 10-12-2012 06:15 PM
