Air pressure in rear shocks - Kawasaki Vulcan Forum : Vulcan Forums
 8Likes
post #1 of 12 (permalink) Old 06-12-2017, 05:01 PM Thread Starter
I have a 2013 Vulcan 1700 Nomad. I am trying to figure out how much air pressure to put in the rear shocks. I weigh 230 lbs and my wife weighs about 130. Does anyone have advice on maybe where to start? We ride together 90 percent of the time. Right now there appears to be no pressure in them.... Thanks!!
2013Kawanomad is offline
post #2 of 12 (permalink) Old 06-12-2017, 06:47 PM
Diggles's Avatar
Year/Make/Model: 2012 Nomad
Color: Red & Silver
I have 2012 Nomad- have dampener set on 3 & usually ride 2 up with 23lbs in shocks. All a matter of trial & error, get yourself a zero loss pump
2012 Nomad 1700
highwaybum likes this.
2005 Classic 800 (sold)
2012 Nomad 1700
Ivanized(2)
RACNRAY throttle mod,Avon Air grips
Vance & Hines slip ons
HD highway pegs
Grasshopper backrest
S/Steel pannier kick guards
Custom lowers
LED running lights
Diggles is offline
post #3 of 12 (permalink) Old 06-12-2017, 07:43 PM Thread Starter
Hey Diggles
Thanks for the info. 23 lbs will be a good starting point. I Have ordered a zero loss pump. Thanks so much for your response.
Diggles likes this.
post #4 of 12 (permalink) Old 06-12-2017, 08:21 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Run 20lbs set on 3,about what diggles runs
Diggles likes this.
revrider is offline
post #5 of 12 (permalink) Old 06-17-2017, 08:56 PM Thread Starter
Got my zero loss pump today. Was at 0 psi. Pumped it up to 23 psi. Will try it out tomorrow. Thanks Diggles and Revrider!!
post #6 of 12 (permalink) Old 06-17-2017, 09:06 PM
revrider's Avatar
No prob,,let us know how u like,btw run rear tire at 36
revrider is offline
post #7 of 12 (permalink) Old 06-17-2017, 09:21 PM Thread Starter
Revrider, can you use the zero loss pump to inflate tires?
post #8 of 12 (permalink) Old 06-17-2017, 09:29 PM
revrider's Avatar
Don't c why not,I use a little compressor on tires,The air shocks are touchy ,use only a pump on them,mite take ya a while pumpn the tires
revrider is offline
post #9 of 12 (permalink) Old 06-17-2017, 09:36 PM Thread Starter
I will give it a try. I have a compressor too but can be a bear to get it hooked up and disconnected without losing pressure. Will drop rear tire pressure down to 36 from 40. Thanks again for the help!
post #10 of 12 (permalink) Old 06-19-2017, 06:41 PM Thread Starter
Went on a couple of rides in the last few days. Real nice change in stability with air in the shocks! Thanks again for the advice!!
Diggles likes this.
Air pressure in shocks Shock Vulcan 1700 15 11-25-2014 10:00 AM
Air Pressure in Rear Shocks-Classic KarateMoto Vulcan 1700 7 05-10-2014 04:51 PM
Question about Tire Pressures and Air Shock Air Pressure Dannjennyn Vulcan 1700 9 04-19-2013 08:45 PM
Thinking of Designing an Oil Pressure adapter for oil pressure and temp gauge bikeman2011 Vulcan 900 1 04-20-2011 05:01 PM
Correct Air Pressure on Showa Shocks edd92002 Vulcan 1500 4 05-23-2010 01:00 PM
