Rattling sound in pipes - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 06-11-2017, 09:43 PM Thread Starter
VulcanDan61's Avatar
Year/Make/Model: 2011 Nomad
2011 Nomad, purchased as new leftover in Nov 2015, 20k miles, stock pipes. Hearing a rattling sound inside the pipes at low speed/RPM. Wasn't there before. Sounds like something may be loose inside the pipes.
Thoughts?
VulcanDan61 is offline
post #2 of 5 (permalink) Old 06-12-2017, 12:23 AM
Glenn54's Avatar
Year/Make/Model: 2013 Voyager
Color: Blue/Black
Have you checked the mounts and clamps to make sure they're not loose?
Kawasaki rear speakers
VN 1500 Kickstand
Ipod adapter
Kuryakyn Longhorn Offset Highway Pegs
Garmin 390LM w/TPMS
Glenn54 is offline
post #3 of 5 (permalink) Old 06-12-2017, 01:46 AM
Does the V exhaust have rivoted plates at the end like the 900? If so, I'd check those rivots out. I had to replace mine because they were loose causing the end plates to rattle.
I'm gone!
crazyriderguy is offline
post #4 of 5 (permalink) Old 06-12-2017, 06:17 AM
Year/Make/Model: 2013 Kawasaki Vulcan Nomad 1700
Color: Titanium and Black
Thoughts?
Did you drill out the baffles in the mufflers. It happened on my 13 Nomad 1700. When I drilled the left muffler out, I could not get one plate out and it got stuck. Because it was the left side, I haven't taken the time to remove it to shake the plate out. That can cause a rattle.
Ultimate Seat with Driver Backrest
Ivan's ECU flash 2
Freedom performance Slip on mufflers
Luverne Kawasaki Lowering Kit
Batwing fairing
Darkside 205/60/16 with Endeavor reversed trike
Huddleston is offline
post #5 of 5 (permalink) Old 06-12-2017, 08:56 AM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
Thoughts?
An image of a small boy sticking pebbles in your exhaust is the first thing I thought of.
D-Dub is offline
Front brake pad rattling dakotabobcat Vulcan 1700 11 07-28-2012 11:21 PM
Rattling Dash Telly Vulcan 1700 11 07-06-2011 01:28 AM
Rattling Speedometer kawabunga Vulcan 500 9 05-10-2011 09:49 PM
Dang rattling soleniods CM1600 Vulcan 1600 5 09-11-2010 09:33 AM
Rattling and Sticking WoodMath Vulcan 900 14 06-06-2009 10:25 AM
