Valve Stem Hole Diameter - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-11-2017, 02:13 PM Thread Starter
I'm planning on installing a 90 degree metal valve stem in front wheel of a 2016 Voyager. Anyone know what the mounting hole diameter is in the front wheel? Would like to have a replacement stem on hand when I change tires. Thanks!
08Nomad is offline
post #2 of 4 (permalink) Old 06-11-2017, 04:14 PM
gv550's Avatar
Rear wheel is 8 mm, front is 13 mm.
gv550 is offline
post #3 of 4 (permalink) Old 06-11-2017, 08:23 PM Thread Starter
Anyone have a brand, part# for a 90 degree valve stem that they installed in a 1700 Voyager front wheel?
08Nomad is offline
post #4 of 4 (permalink) Old 06-14-2017, 05:41 PM Thread Starter
The metal valve stems I find fit either .453 or .625 diameter mounting hole. Anyone got a source for a 90 degree metal valve stem that will fit the 1700 Voyager 13mm (.512) front wheel?
08Nomad is offline
Anyone know the diameter on the valve stem holes? vulcanSpilot Vulcan 650 S 0 06-02-2017 12:39 PM
Front rim stem diameter StevenVZ Wheels and Tires 0 07-11-2016 11:20 AM
Has Anyone Done A Carb Slide Mod Drilling Additional Hole Or Enlarging Stock Hole? 1994Vulcan88 Engine Work 24 07-14-2013 09:28 AM
does anyone know the stock slide vacuum hole diameter? matt21080 Vulcan 1500 0 07-13-2013 07:32 PM
Valve Stem leak Doublenikkel Vulcan 900 12 09-26-2010 04:01 PM
