Voyager cover - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 06-02-2017, 11:19 AM Thread Starter
Voyager cover
Hello:
New to this site, working though it. Question, i just picked up a 2017 Vulcan Voyager. I am in need of a cover, what do I do about the antenna, apparently I am not able too remove it or bend it out of the way of the cover. Am I over thinking this, is the cover weight on the antenna OK?
Thank you
TheKAWMAN is offline
post #2 of 7 (permalink) Old 06-02-2017, 12:02 PM
Sabre-t's Avatar
Color: Red/Black
I don't know if the antenna could take that stress. The top piece was already broken off mine when I got the bike. It's just ornamental so it does not affect performance. With that top piece gone, I'm afraid I might damage the cover if I tried that.
You can unscrew the antenna, but that may not be the best idea. I've seen a few posts about folks loosing them. Putting some blue loctite on it and letting it dry before screwing it back on (the solvents in loctite will damage the plastic) could help with that. That's what I do (haven't tried the loctite yet). Someone posted here or on another forum that Autozone (?) has a compatible shorty antenna for cheap. Not as good reception, but may be enough for you. I thought I had saved the link somewhere, but I can't find it right now.
I've considered that shorty antenna, or putting a metal grommet in my cover with a smaller rubber grommet (like used for electrical passages) inside that to keep rain out. The antenna could go up thru that hole, or mine can since that top ornament is gone.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #3 of 7 (permalink) Old 06-03-2017, 08:50 AM
smedlin's Avatar
FYI,
You posted this in the "bike of the month" section.
Should have been in the Voyager (1700) section, you would get more responses.
Hopefully MN-Rider will see it and move it for you
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #4 of 7 (permalink) Old 06-09-2017, 05:51 PM
swint's Avatar
Year/Make/Model: 2013 Kawasaki Vulcan Voyager
Color: Blue/Black
Originally Posted by TheKAWMAN View Post
Hello:
[...] apparently I am not able too remove it or bend it out of the way of the cover. [...]
Why do you think you're not able to remove the antenna? You should be able to just unscrew it from the antenna base and throw it in your trunk before covering your bike. Unless they've changed the antenna set-up for some reason since 2013, your antenna is removable.
2013 Vulcan 1700 Voyager
AMA Member
VBA #02802
Ham Radio - KM4EHD
swint is offline
post #5 of 7 (permalink) Old 06-10-2017, 09:16 AM
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
I saw enough posts from Voyager owners saying they lost their antenna on the road somewhere to motivate me to do the dab of Loctite Blue on mine. OEM replacement north of $100.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #6 of 7 (permalink) Old 06-10-2017, 04:32 PM
Sabre-t's Avatar
Color: Red/Black
Be sure to let it dry, at least most of the way, before you screw it back in. There are solvents in Loctite that will damage ABS.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #7 of 7 (permalink) Old 06-14-2017, 04:31 PM
VGER's Avatar
Year/Make/Model: 2009/Kawasaki/Voyager 1700
TheKAWMAN
I have a used Kawasaki Voyager cover that I will sell now that mine in garage kept. If interested PM me.
this link is to the new one on the left https://www.kawasaki.com/Accessories/Vehicle/VN1700A9FA
Riding on the dark side
VGER is offline
Do you cover your bike with a cover? Zzman General Vulcan Talk 11 04-27-2017 06:19 AM
Air intake cover and other cover KappaSigTank Vulcan 1500 7 04-04-2013 12:16 PM
day cover, half cover, cycle shade tymbrewolf Vulcan 1700 0 07-09-2011 11:57 PM
Heal shift cover 1700 Voyager t-bear Vulcan 1700 6 07-21-2010 11:34 AM
iPod Audio on Voyager -Anyone try a FM Transmitter/Charger for iPod on the Voyager? myVoyager1700 Vulcan 1700 6 05-29-2010 02:30 PM
