Drive Belt issue - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 12 (permalink) Old 05-31-2017, 05:52 PM Thread Starter
tinbasher's Avatar
Year/Make/Model: 2009 Kawasaki Nomad
Color: Red
Unhappy Drive Belt issue
Adjusted the belt as it has running to the right on rear pulley. Had over a the factory 5 mm deflection. All was good on the 530 am ride to work on the way home it started making noise. When i got it home the belt is tighter than a guitar string? What did I do wrong?
Buddies Indian factory speck is 28 mm how loose should a person go?
tinbasher is offline
post #2 of 12 (permalink) Old 05-31-2017, 06:42 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Run mine at 8mm 4.5 to 5 too tight even tho manual specs say so,readjust at 8mm see how it is,
revrider is offline
post #3 of 12 (permalink) Old 05-31-2017, 06:57 PM Thread Starter
tinbasher's Avatar
Color: Red
Had it at if not a little more will check again after everything cools down
Thank you
Terry
post #4 of 12 (permalink) Old 05-31-2017, 07:06 PM
revrider's Avatar
Thank you
Terry
Ya think 10mm bout as loose as u want to go,maybe others will chime in
revrider is offline
post #5 of 12 (permalink) Old 05-31-2017, 07:13 PM
Spec says 9mm. Problem is how to measure.
Sent from my SM-G900V using Tapatalk
warrbucks is offline
post #6 of 12 (permalink) Old 06-01-2017, 01:27 AM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
I've found the tension/alignment of the belt stays true after the axle is tightened if I use a ratchet strap to keep the wheel pulled forward against the adjusters. Don't go crazy with the ratchet strap, just snug it up so the axle doesn't get pulled to the rear while you're tightening the axle nut.
And just like a chain, a belt is happier and quieter at the looser end of specs.
D-Dub is offline
post #7 of 12 (permalink) Old 06-01-2017, 08:47 AM
Lumber-jack's Avatar
Year/Make/Model: 2009 Voyager 1700
Did you use a jack to lift bike when adjusting? Did you rotate wheel/belt to confirm tension?
10mm is what I adjust mine to.
CarGuy and Peg like this.
_________________________________
"If you want to feel smart, get stupid freinds..."
Lumber-jack is offline
post #8 of 12 (permalink) Old 06-01-2017, 05:58 PM Thread Starter
tinbasher's Avatar
Color: Red
I will give it a try
Thanks Terry
post #9 of 12 (permalink) Old 06-01-2017, 06:00 PM Thread Starter
tinbasher's Avatar
Color: Red
Yes had the rear wheel off the ground and also rotated the wheel going to give it another shot tonight when i get home. bike is waiting in the garage
post #10 of 12 (permalink) Old 06-02-2017, 02:41 PM
Take a picture of the rear axle nut (both sides) and marking point to confirm wheel didn't move.
WTB Final Drive and drive shaft. ClassicFnAllen Vulcan 750 0 09-20-2011 07:55 PM
Magnificent 2009 Voyager 1700 ! But belt drive ? HenriA Vulcan 1700 11 05-25-2010 09:47 PM
Hole in drive belt. oquirrhvulcan Vulcan 900 5 10-09-2009 08:09 PM
Drive belt deflection-when to adjust? macbig General Vulcan Talk 0 08-04-2009 03:06 PM
Belt Drive on a 800 Classic 800Rider Vulcan 900 7 09-30-2008 10:52 AM
