2013 Nomad 1700 turn signals - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 05-21-2017, 10:42 AM Thread Starter
Year/Make/Model: 2013 Kawasaki Vulcan Nomad 1700
Color: Titanium and Black
I am considering removing the front turn signals to replace them with ones that will allow me to use the Solar Signals Amber/White leds. I am not talking about removing the mounting bar, but instead adding different lights to the existing bar. The Nomad signals will not allow the lenses to be removed as they are glued in place. I want to replace them with clear lenses. I have a couple of questions.
How are the signals mounted to the bar? I have tried removing the screw and pulling them off without success. I afraid to use a lot of force, as I want to be able to reinstall them if this does not work.
Does anyone know if there are two wires or three?
Ultimate Seat with Driver Backrest
Ivan's ECU flash 2
Freedom performance Slip on mufflers
Luverne Kawasaki Lowering Kit
Batwing fairing
Darkside 205/60/16 with Endeavor reversed trike
Huddleston is offline
post #2 of 2 (permalink) Old 05-21-2017, 11:03 AM Thread Starter
Ok, Duh, I see there are three wires. I still need to find out how to take the signals off the bar. I don't see anything about it in the service manual, only how to change the bulb.
Ivan's ECU flash 2
Batwing fairing
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
Rear Turn Signal Problem - Old Signals Work - Replacement Signals Don't merc Vulcan 500 9 06-17-2015 10:01 PM
Turn off self-cancelling turn signals? LordRahl007 Vulcan 1600 20 07-28-2014 11:19 AM
Changing rear turn signals to run-brake-turn Blue Vulcan 900 5 04-01-2013 11:07 AM
Rear Turn Signal Connection Aftermarket Turn Signals dccatfan General Vulcan Talk 7 03-18-2012 05:04 PM
