12v Outlet in Fairing - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 13 (permalink) Old 05-08-2017, 11:34 AM Thread Starter
boy_welder2000's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan 1700 Voyager
Color: Black/Gray
When I use the factory 12v outlet in the fairing on my Voyager, whatever I have plugged in will work itself out just far enough to loose contact. I have tried three different plugs and got the same results with all of them. It doesn't appear that there is a risk of them falling out as they fit in there fairly tight, but the center point moves back just far enough that I have to reach down every so often and push the plug back in to keep the item that I am using charging. Its kind of a pain to keep doing that every 15 or so miles.
Any ideas to keep it plugged in short of wiring in a new plug? It would have been nice if Kawi used a locking type outlet like I have seen in other similar applications.
swint likes this.
2015 Vulcan 1700 Voyager
Ivan's ECU ~ Kuryakyn Long Horn Highway Pegs ~ Chucksters Risers ~ Grasshopper Backrest ~ Dual Horns ~ 34024-1330 Kickstand ~ Kawi Gel Front Seat
2008 Vulcan 900 Classic LT - Traded
2002 Honda CB250 Nighthawk - Sold after 15k miles
boy_welder2000 is offline
post #2 of 13 (permalink) Old 05-08-2017, 11:40 AM
rick's Avatar
I have used several different USB adaptors in mine and never had this problem.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 13 (permalink) Old 05-08-2017, 12:10 PM
I've used a strip of the soft side of a velcro strip around the interior rim of the socket. Stops vibration, movement but slides easy. Wipe the metal with alcohol so the adhesive stocks good.
Sent from my SM-G900V using Tapatalk
swint likes this.
warrbucks is offline
post #4 of 13 (permalink) Old 05-10-2017, 07:29 AM
Year/Make/Model: 2016 Vaquero
Color: White
I have this exact same problem with my 2014 Concours. Constantly reaching forward to push in the adapter for my GPS when it goes out on the highway. Very annoying. If I use the tiny 2-plug USB adapter and push it in there, it stays but the adapters, like the ones for a GPS do not. Have not found a fix for it.
aWanderer is offline
post #5 of 13 (permalink) Old 05-10-2017, 08:31 AM
T Gibbs's Avatar
Year/Make/Model: 2012 Vulcan Voyager
Color: Pearl White/ Beige
I have had the same issue. I wired another outlet into the power wiring in the left side storage door in the fairing. I had a usb adapter for my Bluetooth receiver inserted in and it vibrated out. I just used electrical tape to keep it held in. I've not used the other one very much.
2012 1700 Voyager
Cobra Slip Ons
Kuryakyn Grips
Kuryakyn Highway Pegs
Klock Werks Windshield
Mustang Seat with Driver Backrest
Kenwood Stereo
Soundstream Amp
Engineered adapters with 6-1/2"Polk Audio Front Speakers
Kawasaki Rear Speaker Pods with Polk Audio 5-1/4" Speakers
Ivan's Flash
T Gibbs is offline
post #6 of 13 (permalink) Old 05-10-2017, 12:39 PM
JParton357's Avatar
Year/Make/Model: 2013 Kawasaki Vulcan Voyager
Color: White/Grey
Yes, happened to me all the time. I got so sick of it, that I ended up installing a tiny buck transformer with USB ports out of it to connect my GPS. I got it off Amazon, and can post it, as well as directions if you want. It was easy to install, I just connected it to the existing wiring behind the glove box.
2013 Vulcan Voyager
Traveled West to East
JParton357 is offline
post #7 of 13 (permalink) Old 05-13-2017, 09:29 AM
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
Yes...please post what you got etc. Have same problem on my 2016 Voyager of GPS plug backing out of stock socket. Thanks!
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #8 of 13 (permalink) Old 05-13-2017, 04:50 PM
Peg
Peg's Avatar
I don't use the stock socket at all any more. I've put a dual USB plus a single USB outlet in the trunk, and had another single USB in the front left cubby until I realized I didn't use it much any more since there's not much room in there - took it out.
My dual outlet is like this one on Ebay, though I picked mine up on Ali Express. It's not top quality, and despite what the listing says only one port is 2.1 amps, the other is 1.0. The other issue I have is that the plugs are very tight, but at least I know they won't dislodge. My advice would be to get one that's not quite so cheap.
Here's a picture of the single outlet in the trunk. The dual is on the other side in the same place.
My GPS is a Garmin, which needs a proprietary power lead from a cigarette style socket, or it won't work properly. So I just wired one of those inside the fairing with the power lead permanently plugged into it (taped and zip-tied tightly), and push the lead inside through an opening under the radio when it's not being used.
Name:	trunk USB outlet.jpg
auwing1978 likes this.
Paul (Peg) Elliott
Peg is online now
post #9 of 13 (permalink) Old 05-13-2017, 11:58 PM
JParton357's Avatar
Color: White/Grey
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
All you have to do, is remove the glove box from either the left or right side and connect it to the existing wiring. Mine is connected on the left side, to the aux light wiring. The amp draw is negligible.
2013 Vulcan Voyager
post #10 of 13 (permalink) Old 05-14-2017, 12:03 AM
JParton357's Avatar
Color: White/Grey
My GPS is also a Garmin, and finding a cable that just charges it was a pain. I found this a few months ago, and it works great on my unit. I have it connected to the buck transformer and wrapped the connection with electrical tape. The cable may work with you unit as well (hopefully lol).
2013 Vulcan Voyager
Last edited by JParton357; 05-14-2017 at 12:04 AM. Reason: Edited to include cable link
Adding a 12V outlet fran.harper Vulcan 900 7 05-11-2014 08:19 AM
Wiring in a 12V power outlet MichelleS Vulcan 800 15 01-23-2012 09:30 AM
?Source for chrome handlebar mount 12v outlet? bigmoe Vulcan 900 12 01-17-2012 11:45 PM
Cheap 12V outlet install for 1500 Classic threedchief Vulcan 1500 4 12-23-2009 02:18 PM
12v outlet installed bigmoe Vulcan 900 10 10-17-2009 10:42 AM
