Voyager Brakes - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By D-Dub
post #1 of 9 (permalink) Old 04-24-2017, 08:58 AM Thread Starter
T Gibbs's Avatar
Year/Make/Model: 2012 Vulcan Voyager
Color: Pearl White/ Beige
Voyager Brakes
My 2012 Voyager is not the ABS model. When I hit the rear brake while riding I hear a buzzing noise from the right side behind me. First I thought it was something with the LED lights on the rear of the trunk, but it doesn't do it when I hit the front brake, so it's not that. I was just wondering if the rear brakes are ABS on it. It only does it when riding fairly fast, not when stopped or at a low speed.
2012 1700 Voyager
Cobra Slip Ons
Kuryakyn Grips
Kuryakyn Highway Pegs
Klock Werks Windshield
Mustang Seat with Driver Backrest
Kenwood Stereo
Soundstream Amp
Engineered adapters with 6-1/2"Polk Audio Front Speakers
Kawasaki Rear Speaker Pods with Polk Audio 5-1/4" Speakers
Ivan's Flash
T Gibbs is online now
post #2 of 9 (permalink) Old 04-24-2017, 11:42 AM
rick's Avatar
Am willing to bet its air moving through the holes in the rotor you are hearing. I sometimes hear a hissing noise from my 800 when applying the brakes, for the same reason.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 9 (permalink) Old 04-24-2017, 03:03 PM
I thought all Voyagers after 2011 had ABS? Guess I'm still learning about these Vulcans
snowtop57 is offline
post #4 of 9 (permalink) Old 04-24-2017, 03:47 PM Thread Starter
T Gibbs's Avatar
The noise doesn't sound like air through the rotor. It sounds like a relay clicking really fast
post #5 of 9 (permalink) Old 04-25-2017, 09:17 AM
Year/Make/Model: 2011 Vulcan Voyager
Color: Blue/Silver
Sounds like it may be a problem with the pads vibrating. I'd take them out, clean the dust out, grease where the pistons meet the pads (use grease designed for this purpose) and then see what it does.
Bluemeanie is offline
post #6 of 9 (permalink) Old 04-25-2017, 10:10 AM
boy_welder2000's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan 1700 Voyager
Color: Black/Gray
ABS was an option from 09-14. It is standard in 15s and up
2015 Vulcan 1700 Voyager
Ivan's ECU ~ Kuryakyn Long Horn Highway Pegs ~ Chucksters Risers ~ Grasshopper Backrest ~ Dual Horns ~ 34024-1330 Kickstand ~ Kawi Gel Front Seat
2008 Vulcan 900 Classic LT - Traded
2002 Honda CB250 Nighthawk - Sold after 15k miles
boy_welder2000 is offline
post #7 of 9 (permalink) Old 04-25-2017, 10:15 AM
rozie's Avatar
Year/Make/Model: 2015 Vulcan Vaquero ABS SE
Displacement/CC's: 1700cc
Color: metalic carbon grey
if it were my bike I would pull the right saddlebag off and look at the rotor for any signs of grooves or scaring on the rotor. or better yet take the caliper off and check the pads for wear. also look for anything that might be loose or hanging down. on my vaquero there is only 2 bolts that hold the saddlebag on the frame.
2015 vaquero ABS SE {carbon grey}
12in. windshield
k&n air filter
freedom performance true duals
ivans ecu flash
kuryakin longhorn cruise pegs
sagebrush saddlebag chaps
oem aux lights
grasshoper driver backrest
black isso grips
chucksters risers
isso grip helmet locks
rozie is offline
post #8 of 9 (permalink) Old 04-25-2017, 10:20 AM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
Nearly every bike I've had with a drilled rear disc has made some kind of noise. Hard to describe the sound in words, but here goes. Wizzzzzzzzzz LOL. I chamfered the holes of the rear brake rotor on my last bike and that all but eliminated the noise for a few hundred miles. Sure it came back but that convinced me the noise was caused by the holes in the rotor and it's normal.
TX1700 likes this.
D-Dub is offline
post #9 of 9 (permalink) Old 04-25-2017, 10:37 AM
rozie's Avatar
I guess you guys have better hearing than me. not to say that the noise is not there BUT, i wear earplugs when I ride and have cobra slipons also and when im slowing down or comming to a stop all I hear is the pipes burbling and popping so any brake noise the bike might make would have to be louder than the mufflers to hear it.
12in. windshield
k&n air filter
ivans ecu flash
oem aux lights
black isso grips
chucksters risers
rozie is offline
Brakes on a Voyager. new kawi rider Vulcan 1700 2 05-20-2013 07:11 PM
Question 2010 Voyager brakes chuckster131 Vulcan 1700 15 05-12-2012 06:45 PM
Front Brakes on 500 ggreene1 Vulcan 500 4 03-23-2009 10:43 AM
Intermittent (brakes?) noise bsbd Vulcan 1600 0 12-06-2008 07:32 PM
