No turn signals/hazard lights - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 04-10-2017, 07:40 PM Thread Starter
Biker Dash's Avatar
Year/Make/Model: 2011 Kawasaki Vulcan Nomad
Color: Metallic blue/silver
Send a message via Skype™ to Biker Dash
While out on my ride today, the turn signals cut out on me. Checking the lights, I found that the hazard lights are not working either. At some point between the intersection of 201 and 148, and downtown Madison, (about a 15 minute ride) that is when they gave out.
Was a dry day. No rain at all. So I do not believe a wet switch housing would be the cause.
A blown fuse? I assume the fuse would be under the seat, near the battery. Any guidance towards helping me find the solution to my light issue is greatly appreciated.
2011 1700 Nomad -- "Princess Celestia"
2003 1500 Dodge Ram Quad Cab 5.9 "Nightmare Moon"
Biker Dash is offline
post #2 of 19 (permalink) Old 04-10-2017, 08:51 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Biker,think owners manual has fuse locations
revrider is offline
post #3 of 19 (permalink) Old 04-10-2017, 09:12 PM
Glenn54's Avatar
Year/Make/Model: 2013 Voyager
Color: Blue/Black
My Voyager manual shows the fuse boxes are under the seat. I'd bet yours are too. I tried to copy a pic of the page but I guess I'm not smart enough to do that.
Kawasaki rear speakers
VN 1500 Kickstand
Ipod adapter
Kuryakyn Longhorn Offset Highway Pegs
Garmin 390LM w/TPMS
Glenn54 is offline
post #4 of 19 (permalink) Old 04-10-2017, 10:18 PM Thread Starter
Biker Dash's Avatar
Rev, if I had my owners manual available, I would have looked it up. Sadly, I cannot find the bloody thing.
post #5 of 19 (permalink) Old 04-10-2017, 11:45 PM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
There's a 10A turn signal relay fuse located in fuse box 1 in front of the battery under the seat.
D-Dub is offline
post #6 of 19 (permalink) Old 04-10-2017, 11:50 PM
D-Dub's Avatar
If the fuse is ok, I'd try cycling the hazard light switch several times with the key in the off position. Then turn key on and see what you have.
D-Dub is offline
post #7 of 19 (permalink) Old 04-11-2017, 06:58 AM
CarGuy's Avatar
Year/Make/Model: 2014 Nomad ABS
Color: Black/White
As D-dub says. There are 2 fuse boxes under the Nomad seat. Both are clearly marked on the cover what the fuses are for. Beware that I had a friend's bike lose his turn signals. All the fuses looked good so we kept checking for other problems. It wasn't until we started replacing the fuses one at at time that we found the culprit. Even though it looked good, it wasn't.
Go for the ride!
2014 Kawasaki 1700 Nomad ABS
2008 Kawasaki 900 Classic LT (sold 2015 42k miles)
1975 Kawasaki KZ400 (sold ~1985)
1970 Suzuki TS250 Scrambler (stolen 1971)
1968 Bridgestone 200 MKII RS (sold 1970)
Patriot Guard Rider
USN 1971-75
CarGuy is offline
post #8 of 19 (permalink) Old 04-11-2017, 12:39 PM Thread Starter
Biker Dash's Avatar
Tried that. No dice.
Gonna try just replacing the fuse with a new one, see if that fixes it. I found the appropriate fuse a bit ago, but it looks fine...
post #9 of 19 (permalink) Old 04-11-2017, 12:48 PM Thread Starter
Biker Dash's Avatar
Okay, I just tried a new fuse, and tried D-dub's trick... no uck at all. Flasher unit? Is there one, and where? Under the seat?
post #10 of 19 (permalink) Old 04-11-2017, 02:21 PM
D-Dub's Avatar
According to the service manual the signal flasher relay is located right where that red taped wire is in your photo.
D-Dub is offline
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
No dash lights no running lights wont start FTW2017 Vulcan 1500 0 09-26-2017 10:13 PM
No start, no indicator lights, no sound Logickle Vulcan 500 21 07-22-2015 07:41 AM
Turn rear turn signals to running lights???? gibi Vulcan 900 18 05-19-2015 03:22 PM
Hazard lights. dun2wice Vulcan 900 2 07-22-2011 10:49 AM
