Headlight plug - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By btom
  • 1 Post By revrider
post #1 of 8 (permalink) Old 04-02-2017, 05:44 PM Thread Starter
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Headlight plug
I am Having trouble getting the headlight plug off,Don't have a ton of room,tried wiggling it ,just doesn't want to budge,any tricks or suggestions?Have to replace the lens and bulb,without breaking anything
revrider is offline
post #2 of 8 (permalink) Old 04-02-2017, 06:40 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
don't break it, just keep on wiggling up and down then left and right, it should come, be patient
MarkinFairfax likes this.
btom is offline
post #3 of 8 (permalink) Old 04-02-2017, 06:51 PM Thread Starter
revrider's Avatar
Patient? me??not one of my traits but will do.plug and wires look good ,no burns that I can c,will keep workn on it,took batt out just in case,Nothin i can put under to pry it up???or better to keep wigglin,,hate electronics
revrider is offline
post #4 of 8 (permalink) Old 04-03-2017, 07:09 PM Thread Starter
revrider's Avatar
Spent 45 minutes on the plug tonite,just won't come off,any other thoughts,am I missing a tab??just shouldn't be this difficult,Ready to take it to the shop
revrider is offline
post #5 of 8 (permalink) Old 04-03-2017, 07:40 PM
Year/Make/Model: 2012 Kawasaki Nomad
Color: Imperial Red / Silver
Rev, if you have another set of hands there have them hold the light while using both of your hands to work the headlight bulb connector off. If that doesn't work with your assistant holding the light carefully use a screwdriver to slowly pry the connector a little bit at a time on each prong. All the best.
MarkinFairfax is offline
post #6 of 8 (permalink) Old 04-03-2017, 08:30 PM Thread Starter
revrider's Avatar
Yea,will try that thanks,Don't want to get too aggressive w it,thought maybe there was a tab but don't think so,will keep tryn,,,,,Damn did sway bar links on my truck faster than changin this light,thanx
revrider is offline
post #7 of 8 (permalink) Old 04-04-2017, 01:25 AM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
I had my headlamp off once and don't remember having to do anything unusual.
Giving a little pry at each terminal may do the trick or at least expose the problem.
D-Dub is offline
post #8 of 8 (permalink) Old 04-11-2017, 05:50 PM Thread Starter
revrider's Avatar
Problem solved,Got fed up,took it to my shop,He changed out the MELTED Plug and lens housing,inspected it ,40 bucks,,,,lesson learned bout 100w bulbs on a stock configuration ,was a nice bright light tho,charging system checked out ok
D-Dub likes this.
revrider is offline
trade my aftermarket headlight for stock 900 custom headlight doughrek Bikes For Sale 2 07-17-2011 12:02 AM
spark plug life and brand stevem Vulcan 2000 10 05-10-2011 06:27 AM
WTT cyclopse / wave headlight & mount for stock vulcan 900 headlight & mount doughrek Wanted to buy or trade Items 0 06-09-2009 12:20 PM
NGK DPR5EA-9 Spark Plug on 1500fi GiveThanks General Vulcan Talk 0 04-25-2009 12:33 AM
Hotter Plug for the 500 steve1431 Vulcan 500 0 09-01-2008 09:46 AM
