Back to OEM Air Filter - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By Peg
  • 1 Post By Peg
post #1 of 6 (permalink) Old 03-30-2017, 01:16 AM Thread Starter
Diggles's Avatar
Year/Make/Model: 2012 Nomad
Color: Red & Silver
About to remove BAK and go back to factory set up with a K & N filter. Apart from reinstalling OEM plate & connecting air sensor anything else need to be done?
2005 Classic 800 (sold)
2012 Nomad 1700
Ivanized(2)
RACNRAY throttle mod,Avon Air grips
Vance & Hines slip ons
HD highway pegs
Grasshopper backrest
S/Steel pannier kick guards
Custom lowers
LED running lights
Diggles is offline
post #2 of 6 (permalink) Old 03-30-2017, 02:11 AM
Peg
Peg's Avatar
Nope. That's it. I did the same thing, and with Ivan's flash in and my EJK hanging on a nail over my workbench, it's now my preferred setup. There's such a marked performance improvement over the OEM ECU that any slight loss in performance as a result of the lesser intake volume isn't at all noticeable. The lesser intake noise though, is very obvious.
Diggles likes this.
Paul (Peg) Elliott
Peg is online now
post #3 of 6 (permalink) Old 04-01-2017, 02:09 AM Thread Starter
Diggles's Avatar
Color: Red & Silver
Thanks Peg, does the crankcase breather go thru the top of the plastic housing on the OEM air cleaner side?
2012 Nomad 1700
Ivanized(2)
HD highway pegs
Custom lowers
LED running lights
Diggles is offline
post #4 of 6 (permalink) Old 04-01-2017, 02:58 AM Thread Starter
Diggles's Avatar
Color: Red & Silver
And did you leave your air switching hose plugged?
2012 Nomad 1700
Ivanized(2)
HD highway pegs
Custom lowers
LED running lights
Diggles is offline
post #5 of 6 (permalink) Old 04-01-2017, 04:53 AM
Peg
Peg's Avatar
I've left the hose which runs from the 11 o'clock position in the back of the right side airbox plugged, and IIRC the crankcase breather consists of a short rubber hose that runs from the back of the front cylinder into a hole in the top of the crossover tube? Chuckster supplied a long piece of hose that clamps there, running to the back of his intake plate. That one comes off, and the short hose goes in it's place.
Part # 92192 in this diagram
Name:	Air cleaner.JPG
Diggles likes this.
Paul (Peg) Elliott
Peg is online now
post #6 of 6 (permalink) Old 04-01-2017, 06:34 PM Thread Starter
Diggles's Avatar
Color: Red & Silver
Thanks Peg, I just kept Chucksters longer pipe in the crossover which should still be OK. Just need to get rid of visitors now so I can go for a spin to test it
2012 Nomad 1700
Ivanized(2)
HD highway pegs
Custom lowers
LED running lights
Diggles is offline
How Tight for Air Filter Casing on new K&N Filter Romper Vulcan 900 0 03-24-2015 10:57 AM
'04 Meany: Why intake and air filter on right? My OEM air filter on left. kissmydrums Vulcan 1600 1 02-17-2015 09:51 PM
