Saddlebag locks on Vulcan 1700 Voyager - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-28-2017, 08:13 PM Thread Starter
Does anyone know how to change out the locks on the OEM saddlebags? I have a new saddlebag but it comes with a rubber plug where the lock should be. I want to take the lock (tumbler) off the old saddlebag and put it on the new one.
Thanks!
Corwin38 is offline
post #2 of 7 (permalink) Old 03-28-2017, 08:56 PM Thread Starter
Failed to mention....this is on a 2016 bike.
Corwin38 is offline
post #3 of 7 (permalink) Old 03-28-2017, 09:49 PM
dlars's Avatar
Sorry I can't help as I've never done that but maybe it would be easier to just unbolt the whole mechanism from your old one.....if you have it available
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #4 of 7 (permalink) Old 03-29-2017, 06:58 AM
tcheekva's Avatar
You will have to disassemble to get the cylinder out. Just swap the whole lock assembly. It is not that hard.
2009 Classic LT 1700 avg 38mpg
Added factory cruise control
Converted to nomad exhaust
V&H Twin Slash Cut slipons
USA Trailer Store Fairing
HD Tour Pack
Avon Grips
Kuryakyn LongHorn Pegs
Mustang Wide Touring w/studs backrest
Throttle Body Gasket
Thunder Mfg OEM Cover BAK
Pipes wrapped
Ivans ECU Flash
Custom Trailer Hitch
tcheekva is offline
post #5 of 7 (permalink) Old 03-29-2017, 08:19 AM Thread Starter
Was really hoping to avoid that since the original units are held in by screws that appeared to be glued or loc-tited. I stripped the heads on the old unit and had to use a Dremel to cut them out.
Corwin38 is offline
post #6 of 7 (permalink) Old 03-29-2017, 09:19 AM
tcheekva's Avatar
They are locktite in. One key to remember is they are not phillips head screws. They are JIS screws. The JIS screwdrivers work alot better. I picked up a set on amazon to use on my metric bikes. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
HD Tour Pack
Avon Grips
Pipes wrapped
Ivans ECU Flash
tcheekva is offline
post #7 of 7 (permalink) Old 03-29-2017, 09:22 AM Thread Starter
Thank you very much!! I never would have known that.
Corwin38 is offline
900LT saddlebag locks JerryJ Vulcan 900 12 02-07-2016 07:15 PM
simple saddlebag locks vulcanfitness Vulcan 900 1 09-06-2013 09:31 PM
Heritage Saddlebag Combo locks V2KRider Vulcan 2000 0 03-29-2011 01:26 AM
Saddlebag locks? X-Rider Vulcan 900 1 02-09-2011 08:58 PM
