Oil Filter removal using Lisle 63600 - Kawasaki Vulcan Forum : Vulcan Forums
 7Likes
  • 7 Post By GGB6259
post #1 of 8 (permalink) Old 03-24-2017, 09:37 AM Thread Starter
Year/Make/Model: 2012 Kawasaki Nomad
Color: Imperial Red / Silver
Well friends it looked as if my new (new to me) Nomad was going to embarrass me again with a oil filter that would not budge using a correct size cap wrench that just spun and a plier vise grip oil filter gizmo that just left dents. I made arrangements to have the filter tended to by a local Indy, the shame of it all. So last night I started looking at some postings for spin on oil filter removal issues and I found many DIYers have had similar experiences with both cars and motorcycles with the previous oil filter installer putting the Magella Gorilla twist on it or more ominous the stealer making sure of a return visit? What I found was people having almost universal success using a Lisle import car filter wrench # 63600. Go online and found that my Advance auto parts had one in stock so I go there and bought one for 13 bucks after tax. In the morning I go out and fit the Lisle over the old filter, attached my 3/8" ratchet which did not fit exactly square due to the frame bar under the radiator. So here I am bike on its side stand Lisle in place abet cocked angle I begin to apply downward pressure using my foot on the ratchet handle. The cam design on Lisle caught the dented old filter in its jaws and began to turn it. Holy happy dance batman! Got the old filter off the rest of the way using the cap wrench and put the new Kaw filter losing less than a couple of tablespoons of oil plus what was still absorbed in the filter media.
MarkinFairfax is offline
post #2 of 8 (permalink) Old 03-24-2017, 08:01 PM
Ya mean you never had to pound a screwdriver thru the filter body and mangle it off without cutting yourself?
Doing so makes you an over acheiver....
Peg, revrider, snowtop57 and 4 others like this.
Gary
SW Michigan
2009 Kawasaki Voyager
GGB6259 is offline
post #3 of 8 (permalink) Old 03-24-2017, 10:05 PM Thread Starter
Read about the Vladimir the Impaler method too. Yikes😬
post #4 of 8 (permalink) Old 03-25-2017, 07:22 AM
boy_welder2000's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan 1700 Voyager
Color: Black/Gray
I had to use a screwdriver for a Fram filter once. That was the last time I used a Fram.
2015 Vulcan 1700 Voyager
Ivan's ECU ~ Kuryakyn Long Horn Highway Pegs ~ Chucksters Risers ~ Grasshopper Backrest ~ Dual Horns ~ 34024-1330 Kickstand ~ Kawi Gel Front Seat
2008 Vulcan 900 Classic LT - Traded
2002 Honda CB250 Nighthawk - Sold after 15k miles
boy_welder2000 is offline
post #5 of 8 (permalink) Old 03-25-2017, 04:06 PM
Sabre-t's Avatar
Color: Red/Black
I have done the screwdriver method, but never had to again after I tried the old leather belt method. Basically a homemade version of a strap wrench. If you need the extra leverage, grab the belt with a pair of channel lock pliers or some vise-grips. Cheap and effective.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #6 of 8 (permalink) Old 03-25-2017, 06:52 PM
VGER's Avatar
Year/Make/Model: 2009/Kawasaki/Voyager 1700
Cool My solution to the oil filter dance on my '09 Voyager
I too have had this issue. I got tired of that dance. The K&N 303 oil filter has a nut removal on the top and is available in either black or chrome. easier option for me. in black currently only $7.61 at Walmart.
https://www.walmart.com/ip/29217703?wmlspartner=wlpa&selectedSellerId=0&adid= 22222222227019396180&wl0=&wl1=g&wl2=c&wl3=51809067 311&wl4=aud-273067695102la-83211221231&wl5=9010983&wl6=&wl7=&wl8=&wl9=pla&wl1 0=8175035&wl11=online&wl12=29217703&wl13=&veh=sem
Riding on the dark side
VGER is offline
post #7 of 8 (permalink) Old 03-25-2017, 07:20 PM Thread Starter
Good tip on the K&N 303 at Walmart !
post #8 of 8 (permalink) Old 03-30-2017, 09:40 PM
Akgeezer's Avatar
I had service done at my local dealer while under warranty. You know, just to cover my butt should a warranty issue come up. This year I changed the oil & filter myself. Yes the gorilla must have changed my oil & filter, too! Breaking the drain plugs loose was all I could do. They were torqued down way too much. Then to the oil filter. I used a cap type filter wrench that always worked for my 900. No way would it break loose. I was considering the screwdriver method, but thought I'd go and buy a plier type wrench and give it a try. Again it was all my effort and many attempts before it finally began to spin. Totally unnecessary! I've heard the dealers often give the oil change jobs to the new employees. Maybe that's what happened, but it still pissed me off.
I've also gone to the K&N 303. Every advantage is appreciated and I think it's a decent filter for the riding I do.
Akgeezer is offline
Tires, oil & filter, and air filter. bdrewitz General Vulcan Talk 2 05-09-2016 08:15 PM
Oil filter removal mikecustom900 Vulcan 900 33 12-29-2012 02:48 AM
Question re oil filter removal BIGLARRY Vulcan 1500 8 03-28-2012 10:23 PM
Anyone using this air filter? Toddmog Vulcan 800 8 01-30-2012 02:59 AM
94 1500- using oil 2tonbuick Vulcan 1500 1 02-02-2009 12:57 AM
