Scootworks SWR-21E Voyager Risers - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 2 Post By boy_welder2000
post #1 of 4 (permalink) Old 03-20-2017, 09:58 PM Thread Starter
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
We installed a set of these risers Friday on my 2016 Voyager. Fairly easy installation and brought the stock handlebars up and back an inch plus. Plenty of cable and no need to reroute anything.
Scootworks - Kawasaki Handlebar Risers, PhatRisers, Riser Extensions, & Riser Accessories
Your Shopping Cart
$84 shipped using the smc814 discount code shown ($5 bucks off)
Much more comfortable arrangement for me now....not reaching with my fingertips for the grips.
Note that the bolts that come with the Scootworks risers are 22 mm...the stock bolts are 19 mm. Instructions mention the stock 19mm but do not say the bolts provided are bigger.
And get the washer underneath snug on the bottom with your fingers before inserting the new bolt. If you don't the washer hangs up and bolt will not fully engage. Def a 2 person job and have some long extentions for your ratchet to get the bolts off and on. And the bars are heavy...be sure to cover the gas tank and have a buddy hold the bars when the 4 bolts are loosened.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #2 of 4 (permalink) Old 03-21-2017, 08:44 AM
boy_welder2000's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan 1700 Voyager
Color: Black/Gray
I put on the Chuckster's risers this past weekend VN1700 Nomad, Classic, and Voyager Handlebar risers ? Chucksters Customs basically the same thing as Scootworks. An extra hand would be helpful, but it can be done with one person if you take your time and are careful. My stock nuts were 20mm and the new nuts are 22mm. Swivel extensions are a must. The left riser is a pain to get on and off because the main harness runs right under the nut, but it can be done. The book says to torque the new nuts to 44 ft-lb, but they are much tighter then that from the factory. My electric 1/2" impact rated at 160 ft-lb didn't even budge them. The lower riser (the part the bar sits in) has arrows and those go to the top. The clamp (the piece with 2 bolts) has a small cut on them and that goes to the bottom
Peg and auwing1978 like this.
2015 Vulcan 1700 Voyager
Ivan's ECU ~ Kuryakyn Long Horn Highway Pegs ~ Chucksters Risers ~ Grasshopper Backrest ~ Dual Horns ~ 34024-1330 Kickstand ~ Kawi Gel Front Seat
2008 Vulcan 900 Classic LT - Traded
2002 Honda CB250 Nighthawk - Sold after 15k miles
boy_welder2000 is offline
post #3 of 4 (permalink) Old 03-21-2017, 09:17 AM Thread Starter
auwing1978's Avatar
Color: Black-Silver
Great write up and your comment about left riser being more difficult to get on is spot on. Same with getting the stock bolts off......they are way way torqued on. And def long swiveled extentions are a must.
post #4 of 4 (permalink) Old 03-25-2017, 07:06 PM
VGER's Avatar
Year/Make/Model: 2009/Kawasaki/Voyager 1700
I've had the Scootworks Phatt Risers on my '09Voyager for about 5 years and love the improved comfort..98,000 miles with them.
Riding on the dark side
VGER is offline
Phat Risers SWR-26 FITMENT REBAR1968 Vulcan 1700 25 08-11-2016 08:40 PM
For Sale Phatrisers SWR-30 Bandit101 Bike Parts, exhausts, etc. For Sale 6 03-22-2016 05:14 PM
ScootWorks SWR-12 Riser Extensions tl40plus Bike Parts, exhausts, etc. For Sale 2 03-17-2014 11:01 AM
Scootworks SWR-11 Riser Black Review sologeeks Vulcan 900 3 11-15-2013 09:00 AM
Scootworks SWR-12 risers installed Kerry Vulcan 900 27 12-02-2010 10:53 AM
