Help needed installing rear brake pads - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Sabre-t
post #1 of 8 (permalink) Old 12-27-2016, 11:35 AM Thread Starter
Year/Make/Model: 2011 Kawasaki Vulcan Nomad
Color: Black & Silver
Hello, few weeks back I had my rear tire replaced on my 2011 Nomad and I noticed after the dealer installed the new tire that the rear brakes started making noise so I removed the rear caliper to inspect the pads and they look fine. Now, here is where my problem started, I am not by any means a mechanic, I can follow simple instructions and do oil changes and minor repairs but never did brakes. I am not able to install the pads back into the caliper. I have the service manual I don't know how the spring stopper goes to prevent the lower pad to move. I placed it I believe same way it was before but when I install the other pad if the lower pad moves the dang thing falls out. I appreciate your help, it is a beautiful day to ride and I am stuck with this!
Name:	Screen Shot 2016-12-27 at 12.12.18 PM.jpg
Nomad1968 is offline
post #2 of 8 (permalink) Old 12-27-2016, 03:41 PM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
Not familiar enough with the brakes on the 1700 to comment on your issue. But over the years I've had better luck installing the caliper bracket, then the pads and lastly the caliper. Hope that helps.
D-Dub is offline
post #3 of 8 (permalink) Old 12-27-2016, 06:38 PM Thread Starter
I tried doing that but same thing. The pad keeps coming out....
Thanks!
post #4 of 8 (permalink) Old 12-27-2016, 09:18 PM
Sabre-t's Avatar
Color: Red/Black
Are you putting the slide pin in on the backside (of the pictures)? I'm not familiar with the Nomad brakes, but from the look of pic next to the diagram, the clip is on correctly, but you don't have the pin in to hold the pads. Put the pin in, then the clip?
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #5 of 8 (permalink) Old 12-27-2016, 09:40 PM Thread Starter
I tried putting the clip first and then the pin. I am going to try to do the pin first and then the clip.
I was following the service manual but there is nothing about the clip....
Name:	Screen Shot 2016-12-27 at 10.36.46 PM.jpg
Name:	Screen Shot 2016-12-27 at 10.36.59 PM.jpg
Thanks!
post #6 of 8 (permalink) Old 12-27-2016, 10:15 PM
Sabre-t's Avatar
Color: Red/Black
Attachment 180074
Attachment 180082
Thanks!
The Voyager brakes are the same as yours (same verbiage as your manual). The clip does go in before the pads (duh, I was thinking about the brakes on my previous bike). I think I know what your problem is, if I remember correctly . It doesn't mention it in the manual, but you have to pull the the caliper body towards the bracket and install the pin and snap pin for the pads to stay in place. If you don't get the snap pin in, the caliper body will push away and the pads will drop out every time.
MN-Rider likes this.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #7 of 8 (permalink) Old 12-28-2016, 07:44 AM Thread Starter
That was it! The pistons need to be pushed into the caliper for the pads to fit. Man how come the service manual says nothing about it! Noise is now gone, the dealer installed the clip the wrong way so it was probably touching part of the disc or something.
Thanks a lot!
post #8 of 8 (permalink) Old 12-28-2016, 11:45 PM
Sabre-t's Avatar
Color: Red/Black
Thanks a lot!
Yea! Glad I was able to help!
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
VN 800A front caliper brake pads... HELP.!.!.!.!.!.!.? Bob the Bobber Vulcan 800 14 06-23-2015 03:22 AM
Advice needed for front brake pads replacement Frenchy Vulcan 900 14 05-02-2013 10:57 AM
Brake Pads Front and Rear..Easy???? kettlinton Vulcan 1600 11 11-13-2011 08:31 PM
installing front brake pads cthair Vulcan 750 2 05-26-2010 08:17 PM
800 Vulcan Classic front brake pads? SPARKY39 General Vulcan Talk 0 04-04-2009 01:19 PM
