Jumping while accelerating - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By RACNRAY
post #1 of 10 (permalink) Old 12-22-2016, 11:02 PM Thread Starter
Blessed1277's Avatar
Good even I have 2009 Vulcan 1700 classic. While in 2nd gear between 30 and 50 mph I get this jump in the bike it's like it coughs for a second an after I get by 50 mile I'm good. It only does this in 2nd gear all other gears are fine anyone have an input on this help if you can
Ride Safe everyone
Live an ride for you an others
Blessed1277 is offline
post #2 of 10 (permalink) Old 12-23-2016, 10:00 PM
dlars's Avatar
Does it happen when you are accelerating hard or soft or both. You should be able to tell if it's an engine sputter or not. It could be the transmission.....shift fork possibly? It's not a good sign that it only does it in one gear. The reason I say that is because I road my buddy's V2K and it's got a shifting problem in 3rd gear. If you get on the throttle hard it pops out then back into gear.....very sudden jerk
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #3 of 10 (permalink) Old 12-23-2016, 10:19 PM Thread Starter
Yes it does only happen in 2nd if I'm on the throttle hard or if I'm just doing the normal acceleration trying to pick up speed
Ride Safe everyone
post #4 of 10 (permalink) Old 12-24-2016, 08:47 AM
Lumber-jack's Avatar
Year/Make/Model: 2009 Voyager 1700
Is your's throttle by wire like Voyager/Vaquero? I suspect it is. If so that's probably why and suggest you do a search in the forums...
_________________________________
"If you want to feel smart, get stupid freinds..."
Lumber-jack is offline
post #5 of 10 (permalink) Old 12-24-2016, 09:11 AM Thread Starter
What would I be searching "Throttle wire problems"
Ride Safe everyone
post #6 of 10 (permalink) Old 12-24-2016, 09:54 AM
RACNRAY's Avatar
SORRY to say but with my 40+ years as a motorcycle technician you have the typical second gear problem/failure. NOT with just the 1700's, but with all skoots.
The jumping you feel has 2 occurrences, the first is second gear jumping OUT of engagement which causes the disruption of power, then the gear re-engages. It can happen once or multiple times.
Until the engine is removed and disassembled to make the repairs, do not ride in second gear in the manner that causes this skipping, to minimize further damage.
I will be glad to completely explain this by fone so shoot me a fone nmber as it's too time consuming to type.
RACNRAY
dlars likes this.
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #7 of 10 (permalink) Old 12-24-2016, 09:59 AM Thread Starter
RACNRAY
Thanks for your posted it helped
Ride Safe everyone
post #8 of 10 (permalink) Old 12-25-2016, 12:48 AM
dlars's Avatar
RACNRAY
Yup, sadly this sounds familiar
iPod Connector
Manual Fan Switch
dlars is offline
post #9 of 10 (permalink) Old 12-25-2016, 10:18 PM
Could just be shaft hump normal in first and second gear
Lmhawk01 is offline
post #10 of 10 (permalink) Old 12-26-2016, 06:49 PM
dlars's Avatar
Elaborate please, because nothing about his tranny problem sounds "normal"
iPod Connector
Manual Fan Switch
dlars is offline
Speedo Problem - Only working while accelerating hard hohahaze Vulcan 800 1 04-18-2015 10:58 AM
Engine cutting while cruising, fine while gettimg on it. thewiesercracker Vulcan 900 18 04-06-2013 11:13 PM
Noise when ACCELerating, not DECELerating Eddiek Vulcan 1500 8 06-16-2012 11:17 AM
Nomad "jumping" while in second gear... ScottyJ General Vulcan Talk 11 03-02-2012 02:42 PM
Back to my 1990~ish Vulcan (NOT) revving/accelerating/gassing above an idle loudjosh81 Vulcan 500 36 10-02-2011 11:40 AM
