Are there any stock length shocks with higher spring rates? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 09-20-2016, 08:53 PM Thread Starter
Is there a company, other than Works Performance, that offers full length shocks with higher spring rates? I have installed Race Tech springs and Gold Valves in the forks plus tuned the stock shocks as best as I can and the rear end is still bouncy. These shocks feel more than under-damped, they need stiffer springs. My searches only turn up shorter shocks and I need all the cornering clearance I have; I sure don't want to lose any by lowering the bike.
I understand that many will say to get the Works Performance but I want to know if there are other options.
Thank you.
Shaun
'12 Voyager 1700
motocyco is offline
post #2 of 10 (permalink) Old 09-20-2016, 09:32 PM
Progressive maybe.....
Gary
SW Michigan
2009 Kawasaki Voyager
GGB6259 is offline
post #3 of 10 (permalink) Old 09-20-2016, 11:19 PM
Sabre-t's Avatar
Color: Red/Black
You have 43 psi in the shock and the pre-load set at 4 and you think the rear is still too bouncy? In Florida?
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #4 of 10 (permalink) Old 09-21-2016, 04:11 AM
Peg
Peg's Avatar
I had a set of Íhlins shocks installed on my Voyager, and they're fantastic. Stock length, and good for any load, one-up or with a passenger. A huge improvement over OEM.
Paul (Peg) Elliott
Peg is offline
post #5 of 10 (permalink) Old 09-21-2016, 05:09 AM
At 43PSI those shocks will fail it's just a matter of time. I'd go with what Peg said about Ohlins. Some the best shocks money can buy and you will spend on them.
Gary
SW Michigan
GGB6259 is offline
post #6 of 10 (permalink) Old 09-21-2016, 10:23 PM
Sabre-t's Avatar
Color: Red/Black
I would never run at 43 psi, but the rear gets pretty stiff with pressures in the higher range and the pre-load on 4. No doubt you can get a smoother ride with a better set of shocks, but he said it was "still bouncy". I'm a big guy (270 lbs) and I find 20 lbs and a pre-load of 3 to be just fine even on rough roads. Of course, others may think that is still too soft. I guess I just should have asked what pressure and pre-load he has it at now, but I was in a bit of a sarcastic mood the nite I wrote that.
'Course, he could just replace the shocks with a metal brace and make a hard tail out of it!
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #7 of 10 (permalink) Old 09-23-2016, 03:09 PM Thread Starter
1. Progressive shocks are all shorter and lower the bike. No good.
2. I'm not sure whet you got 43 psi from, maybe an old post. I currently run about 7-10 psi and 4 for damping. Yes, it is still bouncy.
3. Which Ohlins socks? Are you sure that the springs are stiffer?
motocyco is offline
post #8 of 10 (permalink) Old 09-23-2016, 03:24 PM Thread Starter
I am 180 lbs. and run 7-10 psi preload plus have the dampers set at 4. My comments about cornering clearance should tell you that I sometimes ride aggressively. The bike rides fine over small bumps, it's over dips when the RaceTech front end recovers beautifully and the stock rear shocks bounce like a pogo stick. I could increase the preload to 39 psi but that results in a harsh ride. Since I mostly ride alone I am looking for a higher spring rate so that I can keep the preload low and still make use of the wheel travel.
Chances are that my next touring bike will be a sport tourer like the Concours. But that is probably 5-7 years away.
Thank you.
motocyco is offline
post #9 of 10 (permalink) Old 11-04-2016, 12:10 PM
Ohlins
Please post Ohlins shock model # installed on your Voyager. Thank you
KawMan is offline
post #10 of 10 (permalink) Old 11-04-2016, 04:06 PM
Peg
Peg's Avatar
They were installed by a shop, and while I know the model number (HD146, for a Sportster), I'm not sure what they had to do to get the bushings to fit. I've found the mounting instructions & owners manual... The shock length is 360.5mm, stroke 105mm, and the spring part number is 00480-01, rate 15-24 N/mm.
If I could find the invoice I would check if the bushings were listed... Can't find it sorry.
Paul (Peg) Elliott
Peg is offline
Hey there, hi there, ho there! CRU New Member Introductions 3 09-15-2016 02:11 PM
Correct length for shocks & springs? SpockJenkins Vulcan 500 2 05-11-2014 01:01 PM
Are there any PRO members / builders / tech masters out there AlwaysOnTwo Engine Work 1 06-01-2013 05:12 PM
Stock rear shock length ? MachU Vulcan 900 1 08-18-2012 08:09 PM
Stock length clutch cable breakage Water Rat Vulcan 2000 21 09-19-2011 06:15 PM
