burning oil smell: it's a mystery - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 09-18-2016, 08:20 PM Thread Starter
otter's Avatar
Year/Make/Model: 2015 Voyager
Color: Black/Spark Grey Metallic
2015 Voyager, 12000km on the clock.
It's the strangest thing: If I take a good long coast to a stop sign from highway speed with the throttle closed and don't bother downshifting, every now and then I get a whiff of burning oil after coming to a stop. It's the only time it happens and it's intermittent.
No smoke coming out of the pipes and no burning oil smell from the pipes on takeoff. Had the wife really pay attention today as she rode behind me. Couldn't smell a thing behind the bike when underway, taking off or at a stop sign.
It only happens in the situation I described, the smell seems to waft up from the centre of the bike. It's brief and intermittent. And yeah, I know what an oil burning dying engine smells like. It has me worried and puzzled.
I checked the oil and really haven't used anything over 5000km.
Any ideas?
otter is offline
post #2 of 12 (permalink) Old 09-18-2016, 08:32 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
look at the vent tube?? just a guess
revrider is offline
post #3 of 12 (permalink) Old 09-18-2016, 09:13 PM
dlars's Avatar
Ya I would pull the left cover and air filter. You may be able to tell if the CC vent hose is still on without removing the whole airbox but if not, it pretty easy to do. If that isn't the problem I have no idea......can't be anything too serious as you say your oil level is still up. Good luck.
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #4 of 12 (permalink) Old 09-18-2016, 10:56 PM
Biker Dash's Avatar
Year/Make/Model: 2011 Kawasaki Vulcan Nomad
Color: Metallic blue/silver
Send a message via Skype™ to Biker Dash
I have noticed the same smell on rare occasions on my 2011 Nomad. And I have found not a thing wrong as well.
2011 1700 Nomad -- "Princess Celestia"
2003 1500 Dodge Ram Quad Cab 5.9 "Nightmare Moon"
Biker Dash is offline
post #5 of 12 (permalink) Old 09-19-2016, 06:41 AM
twowheeladdict's Avatar
Why would you do that? Doesn't the engine start lugging if you don't downshift or at least disengage the clutch?
I always downshift so I am ready to accelerate if needed.
Maybe coasting under engine back pressure is the problem. Search for oil on the bike by coasting int the garage that way and get out a powerful light to look around.
twowheeladdict is offline
post #6 of 12 (permalink) Old 09-19-2016, 02:23 PM Thread Starter
otter's Avatar
I only do it if I'm lazy and coasting into a stop. Throttle closed after downshift and coast.
Here's what's inside the airbox: (that's not liquid, it's sticky, nasty gooey sludge)
otter is offline
post #7 of 12 (permalink) Old 09-19-2016, 07:21 PM
dlars's Avatar
Just to confirm, your crank case vent hose is properly attached?
iPod Connector
Manual Fan Switch
dlars is offline
post #8 of 12 (permalink) Old 09-19-2016, 07:47 PM Thread Starter
otter's Avatar
yep, at least on visual inspection. Seems to be doing a good job venting crap into the airbox.
otter is offline
post #9 of 12 (permalink) Old 09-21-2016, 09:37 AM
captj3's Avatar
nothing abnormal about having some oil in there. The oil level can be to high or it is just a build from vapors that pass through that part of the intake. Nothing to worry about. Your car does this too, but it use a PCV vale to control it.
2012 Vaquero Candy Lime Green/Black
1700 Nomad (Deceased)
Cobra Tri-Oval Exhaust
Racnrays Invention (Throttle Mod)
Ivan's Flash
Thunder Tornado Air Kit
captj3 is offline
post #10 of 12 (permalink) Old 09-21-2016, 10:10 AM Thread Starter
otter's Avatar
So I think I solved the stink problem. I got ride of the deposits in the airbox. They were thicker than molasses. No more stink.
I'm thinking on long, closed throttle deceleration, could there be abnormally high venting going on? Hot gasses heat up that sludge and the stink happens....
Thoughts?
otter is offline
Burning rubber smell after riding.... CoVulcanGuy Vulcan 650 S 13 01-16-2018 08:53 AM
Burning oil on startup of 91 Vulcan 88 souls20042 Vulcan 1500 26 09-04-2012 12:34 AM
VN 1500 Burning Oil Abrie Myburgh Vulcan 1500 11 07-07-2011 01:53 AM
Burning Oil dt28255 Vulcan 800 52 08-26-2010 08:50 PM
Burning oil lapimp69 Vulcan 800 1 04-16-2010 11:08 AM
