Replacement oil filter for 2016 Voyager - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 09-12-2016, 11:21 AM Thread Starter
gartdm98's Avatar
Hi guys,
I'm getting ready for a first oil change on my 2016 Voyager and was looking to get K&N filter.
Search tool on K&N website does not bring any compatible oil filters for 2016 Voyager, but does indicate KN-303 for 2015 and earlier.
I have a spare KN-303 for my VN900 and would like to use it.
Does anybody know if there are changes in Voyager design from last year and if it's OK to use KN-303? Or should I look at some other options?
2009 Vulcan 900 Classic.
gartdm98 is offline
post #2 of 12 (permalink) Old 09-12-2016, 12:49 PM
Under "tools" in the header you will find the Advanced Search feature.. Oil filters have been beat about for years...
Gary
SW Michigan
2009 Kawasaki Voyager
GGB6259 is offline
post #3 of 12 (permalink) Old 09-12-2016, 01:06 PM Thread Starter
gartdm98's Avatar
Thanks. This is the first thing I actually did . Used the search and found that KN-303 is compatible. K&N website confirmed that as well, but only for 2015 and earlier years. Nothing comes up for 2016 on there website, hence the question. I just want to make sure that it will work for my scoot. If not I will go with other brands. I just happen to like K&N oil filters because it is easy to remove.
gartdm98 is offline
post #4 of 12 (permalink) Old 09-12-2016, 03:45 PM
no change in years as far as anything I've heard of...
Gary
SW Michigan
GGB6259 is offline
post #5 of 12 (permalink) Old 09-12-2016, 11:57 PM
rick's Avatar
Since you already have one, try it. Am sure it should be good.
2005 800 classic
2012 Voyager ABS
rick is offline
post #6 of 12 (permalink) Old 09-13-2016, 12:25 AM
Peg
Peg's Avatar
If they'd changed the engine in 2016, I'm sure someone would have mentioned it by now
Paul (Peg) Elliott
Peg is offline
post #7 of 12 (permalink) Old 09-13-2016, 08:00 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
check wix filter web site, i think wix 51358 fits all vulcans, you can get wix filters at auto parts stores
btom is offline
post #8 of 12 (permalink) Old 09-13-2016, 09:20 AM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
Kawasaki lists the same part# for all 1700 Vulcans thru 2016. 16097-0008
So no changes.
D-Dub is offline
post #9 of 12 (permalink) Old 09-13-2016, 12:06 PM Thread Starter
gartdm98's Avatar
Thanks for all suggestions. So I guess K&N filter will do.
gartdm98 is offline
post #10 of 12 (permalink) Old 09-14-2016, 11:47 AM
Nixoninc's Avatar
Better oil filter, IMHO...
I'll probably get flamed for this, but IMHO the Purolater PureONE PL14610 is the only filter I'll use for my Voyager. It has a much better filter media and more of it packed inside.
Nixoninc is offline
Oil filter for 2015 Vulcan Voyager 1700?? lom3ardo Vulcan 1700 32 08-09-2017 09:50 PM
Tires, oil & filter, and air filter. bdrewitz General Vulcan Talk 2 05-09-2016 08:15 PM
1700 Voyager Oil filter and drain plug warhammer0106 Oil and Lubrication 3 08-18-2014 02:08 PM
Video Tutorial: changing the oil & oil filter on your bike! beltenebros Vulcan 800 3 09-19-2009 07:18 PM
