New Tires and Front End Shimmy - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 08-31-2016, 06:11 PM Thread Starter
VulcanDan61's Avatar
Year/Make/Model: 2011 Nomad
Hi guys,
Just had a pair of Michelin Commander IIs put on my 1700 Nomad at 10,400 miles. Rode great the first 50 or so miles. Then I started noticing some shimmy (slight wobble in the handle bars) while cornering only to the left. Then it became a slight pulse even while going straight.
What's going on? Balance? Alignment? Bad tire?
I ordered the tires off Amazon and had a shop put them on. Seeking guidance from others who may have experienced the same with these tires before going back to the shop.
Happy and safe riding,
Dan
2011 Nomad: Black & Metallic Gray, Chuckster's Light Bar, Rac'nRay's Throttle Mod, Homemade Oversize Lowers, Kawasaki Trunk, Ivan's Flash
Past:
2014 900 Classic LT: (Sold to a happy buyer)
1975 Suzuki GT 185 (Great little twin)
VulcanDan61 is offline
post #2 of 13 (permalink) Old 08-31-2016, 06:38 PM
hayes's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red|Silver
Sounds like you might have a slight separation (based solely on the information you provided). Especially if right is all good.
I grabbed a fistful of throttle and all my worries disappeared.
|| Former President | Vulcan Riders Association | Chapter 1-30 ||
|| 2012 Kawasaki Nomad | EJK Fuel Controller | Vance & Hines Twin Slash Cut | Thunder Manufacturing BAK ||
hayes is offline
post #3 of 13 (permalink) Old 08-31-2016, 06:43 PM Thread Starter
Hey man, thanks. What do you mean to "separation?" Is it the tire seal coming loose? Does that cause leakage? It seems to be holding air.
My first reaction to these tires leaving the shop was "wow, that's way smoother than the old one." But now it's worse because of the wobble.
Dan
Past:
post #4 of 13 (permalink) Old 08-31-2016, 06:44 PM
hayes's Avatar
Color: Red|Silver
The belts on the tire aren't sitting like they were built. It's hard to explain. I'm on my phone, if you haven't gotten a better explanation when I'm on a computer, I'll write better.
hayes is offline
post #5 of 13 (permalink) Old 09-01-2016, 05:17 PM
hayes's Avatar
Color: Red|Silver
Tread Separation
One of the most common modes of tire failure is tread separation which occurs when the plies of a tire separate from one another. Usually, the tread (with or without attached plies) separates from the carcass or inner plies, exposing the inner liner, belts, and cords. As used in this context, the ply includes one of the steel belts encased in a rubber compound.
Tires are built in layers on a tire building machine while the rubber layers and rubber coated fabrics and belts are in an uncured or “green” state. The fully assembled tire (with all components in their proper places) is then subjected to high temperature and pressure, over time, to cure or vulcanize the assembly. It is this vulcanization process which gives the tire its desired physical properties and bonds the multiple layers or plies of rubber together (both mechanically and chemically) so that they can function as a unit.
That's a good description. Basically, the belts are positioned in a way that ride smooth. When they shift, it can cause a bubble in the tire. It can be hard to see at first, but as the tire wears you will be able to see it. You will get a seemingly random flat spot.
hayes is offline
post #6 of 13 (permalink) Old 09-01-2016, 06:27 PM Thread Starter
This a brand new tire. Are you guys saying I've got a lemon?
Past:
post #7 of 13 (permalink) Old 09-01-2016, 10:42 PM
hayes's Avatar
Color: Red|Silver
It very well could be a manufacturer defect. I only think that because you said it wobbles on left and straight. If it's smooth on right turns, it means that something only on left and straight is causing a problem. Have the tire inspected by the shop that installed it, have them re-balance, and go from there.
hayes is offline
post #8 of 13 (permalink) Old 09-02-2016, 06:45 AM
Nomad2010's Avatar
Year/Make/Model: 2010 kawasaki Nomad
Color: 2-tone Metallic Diablo Black/Metallic Titanium
Question
Originally Posted by VulcanDan61 View Post
Hi guys,
Dan
VulcanDan61, I'm getting ready to order one of these tires on Amazon. Do you know what vendor it came from? (Motorcycle Superstore, Chaparral Motorsports, etc)
"Only a Biker knows why a dog sticks his head out of a car window."
Nomad2010 is offline
post #9 of 13 (permalink) Old 09-02-2016, 08:02 PM Thread Starter
Hey Nomad,
My tires came from oemcycles via Amazon. Still feeling some shimmy. Going back to quiz the dealer when I get a chance.
Dan
Past:
post #10 of 13 (permalink) Old 09-16-2016, 07:18 PM Thread Starter
Still getting wobble. Worse on left turns at maybe 20-45. A little at that speed going straight and turning right. Not much at high speed turning left, right, or straight. Didn't happen before putting on the Commander IIs. Any further thoughts?
Past:
Is it better to be on the low end or higher end of a gear? Chicago-n Vulcan 500 3 05-14-2017 08:02 PM
2 Questions: Tires and how to "un-tweak" front end? Phreon Vulcan 500 4 10-17-2014 07:38 AM
Tires tires tires... :-p OAS Vulcan 1500 13 12-30-2013 11:04 AM
Tires,Tires,Tires Neatstreet5000 General Vulcan Talk 20 04-20-2013 10:58 PM
Shimmy Iceman142 General Vulcan Talk 23 02-15-2013 10:03 AM
