ECU flash done, need to disconnect O2 sensor - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 08-17-2016, 11:23 AM Thread Starter
I have a 2016 Voyager 1700. I am putting the ECU back in today and I need to disconnect the O2 sensor. I don't have a shop manual. What is the best way to go about this?
Thanks!
Corwin38 is offline
post #2 of 12 (permalink) Old 08-17-2016, 11:36 AM
Demoliton Man's Avatar
Year/Make/Model: 2018 Indian Roadmaster
Displacement/CC's: 111 cui
Color: polished bronze over thunder black with silver pinstripe
Just folle the cable from the sensor on the right exhaust. IIRC there is a plug ~ 15-20cm from the sensor, which can be disconnected easy.
Just unplug it - done !
Cu,
Sven
"Democracy is two wolves and a lamb deciding what to have for dinner.
Liberty is a well-armed lamb." - Benjamin Franklin
Harley is cult, Victory is cool, but INDIAN is legend !
MY LIFE - MY RULES !
Demoliton Man is offline
post #3 of 12 (permalink) Old 08-17-2016, 01:34 PM Thread Starter
Got it! Thanks!
Corwin38 is offline
post #4 of 12 (permalink) Old 08-25-2016, 10:31 PM
Bigshooter's Avatar
Year/Make/Model: 2015 Voyager ABS
Is there a trick to unplugging it? I'm pulling pretty hard on mine and it won't let go
Cheers
Bigshooter is offline
post #5 of 12 (permalink) Old 08-25-2016, 11:20 PM
Engineerk9's Avatar
Year/Make/Model: 2016/Vulcan S
Displacement/CC's: 650
Color: Orange
It has a small clip to prevent accidental unplug
Engineerk9 is offline
post #6 of 12 (permalink) Old 08-25-2016, 11:21 PM
Engineerk9's Avatar
Color: Orange
Be aware that unplugging the O2 sensor may give an Error signal, due to the break in the heater circuit
post #7 of 12 (permalink) Old 08-26-2016, 12:33 AM
Bigshooter's Avatar
Yes, thanks. Error signal is there but sending out ECU tomorrow for reflash.
Pipes are on
Cheers!
post #8 of 12 (permalink) Old 08-28-2016, 12:00 AM
cannonballs's Avatar
i had to put a 02 eliminator on mine to stop the ecu going bonkers ,dont know if you will with the flash but they are cheap on flee bay
2010 voyager
v/h performance pro pipe with quieter muffer
pcv with ign
individual gear mapping
auto tune
commander 11 rear tyre
2 inch risers
Allycat air intake
cannonballs is offline
post #9 of 12 (permalink) Old 08-28-2016, 08:21 AM
Engineerk9's Avatar
Color: Orange
Without an O2 sensor in the system the autotune cannot function correctly
Kawasaki (as with all other manufacturers) went to a lot of time & cost to develop an ecu that would fulfill all requirements, including emissions regulations - modern ecus are pretty sophisticated & can rapidly adjust to the majority of mods that we choose to fit - exhausts etc
All ecu's are set to a 14.7 Air/Fuel ratio to meet Emission regs - 13.8 generally gives the best overall performance
The simplest & least expensive power improver is *from my own personal experience) is the Magnum Dyna Boost - wjhich "spoofs" the air inlet temperature, effectively richening the fuel inject over the whole range closed to WOT & injects a millivolt signal into the O2 sensor that "spoofs" the ecu seeing 14.7, when infact it's closer to the 13.8
There's a single adjustment screw zero to 33 turns, so lots of adjustment - it can be dyno'd however, l found half a turn before every ride until I was more than happy with the performance
If not happy, just wind the screw back a turn or so until you are
Mine runs at 6 turns from zero
Fantastic 450klm ride today - 24-25klm/litre - mixed highway 120kph (more or less) country back roads etc
I also use Pulstar spark plugs
post #10 of 12 (permalink) Old 06-24-2018, 10:34 AM
Year/Make/Model: 2010
Color: Black silver
What does the sensor look like. Cant locate it.
Jerry Borsato is offline
Vaquero ECU flash from Ivans performance? rengelen General Vulcan Talk 6 06-02-2017 08:38 PM
Ivan's flash and O2 sensor. kmalek Vulcan 1700 7 10-11-2016 10:44 PM
IVAN'S ECU Flash Edmonton, Alberta group purchase buckey1313 Vulcan 1700 3 06-16-2016 10:04 PM
Question About Ivan's ECU Flash aschamne Vulcan 1700 35 05-05-2016 10:01 AM
Now available: ECU flash for 1700 motors Peg Vulcan 1700 73 04-24-2016 02:10 PM
