voyager 1700 lowers - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 08-06-2016, 08:01 PM Thread Starter
voyager 1700 lowers
has anybody removed the lower fairings to see if that helps with the heat on your legs when riding?
albsharp is offline
post #2 of 6 (permalink) Old 08-06-2016, 09:41 PM
dlars's Avatar
I've had mine off and rode it on a very hot day. It makes no difference and was not worth the bother for me. You can wrap the headers which I have heard makes a difference. I installed a manual fan switch also which I turn on before the temp climbs into the hot region when riding around town at slower speeds. Since doing that I don't really even notice the heat anymore. Some people say the Ivan's re-flash makes a difference also, but I have no first hand experience with that.
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #3 of 6 (permalink) Old 08-06-2016, 10:45 PM Thread Starter
any pics of installation of fan switch... what kind, switch location etc. any hints would be appreciated.
albsharp is offline
post #4 of 6 (permalink) Old 08-06-2016, 11:22 PM
Check out Ray's post here.
https://www.vulcanforums.com/forums/s...ad.php?t=66809
You can also search for "fan switch" and at least two threads show up with location pictures.
chykal is online now
post #5 of 6 (permalink) Old 08-07-2016, 06:24 AM
gv550's Avatar
I have my lowers removed all summertime, it does increase the airflow past my legs significantly although it is no cooler than the ambient air. It is very easy to do, just remove the engine guard complete with plastic (2 bolts each side) and I bolt on Vaquero engine guards with no lowers.
The temperature gauge will read a bit higher because the lowers actually direct air into the radiator, and there is more wind noise and turbulence but I enjoy the extra airflow across my legs and up my jacket.
Garry
2009 Voyager ABS:
Sold at 679,465 kms
Improve handling, suspension and tire life
with Garry's Fork Brace.
gv550 is offline
post #6 of 6 (permalink) Old 08-07-2016, 03:58 PM
dlars's Avatar
Ok OK OK...fan switch wiring info - Kawasaki Vulcan Forum : Vulcan Forums
Thanks for posting this, saved me searching. You can install it wherever you heart desires. I also highly recommend soldering instead of using a posi-tap method if you do it, I had a posi-tap go bad after about 6 months and ended up soldering it in the end. I used an illuminated switch just so I don't forget when it's on.......age you know
iPod Connector
Manual Fan Switch
dlars is offline
Lowers for 1700 CaptainAdam Vulcan 1700 4 08-19-2017 02:16 AM
1700 Classic Lowers Ö Required?? RickyTT Vulcan 1700 5 03-28-2013 04:33 AM
Lowers for 1700 Classics? Double J Vulcan 1700 4 08-11-2012 07:23 AM
Windshield Lowers for use with Lightbar '09 1700 Classic LT mmlanes Vulcan 1700 2 10-15-2011 01:13 PM
Vulcan Classic 1700 - Windshield Lowers and straight highway bars radicalroad Vulcan 1700 3 05-04-2011 05:15 PM
