Error code and cleaning throttle bodies. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 17 (permalink) Old 08-05-2016, 04:22 PM Thread Starter
Biker Dash's Avatar
Year/Make/Model: 2011 Kawasaki Vulcan Nomad
Color: Metallic blue/silver
Send a message via Skype™ to Biker Dash
Okay, I have gotten the Error 18 code a few times, and I have read that cleaning the throttle bodies would probably help things.
Now, the question is, can I get to the throttle bodies to clean them good by just taking off the right side cover? Also, is there a recommended procedure for cleaning them?
2011 1700 Nomad -- "Princess Celestia"
2003 1500 Dodge Ram Quad Cab 5.9 "Nightmare Moon"
Biker Dash is offline
post #2 of 17 (permalink) Old 08-05-2016, 05:22 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Think there is a youtube vid of this if I'm not mistakn
revrider is offline
post #3 of 17 (permalink) Old 08-06-2016, 05:25 PM
dlars's Avatar
Yes, you just have to hold the butterfly open with something then clean the throttle body using a clean rag or toothbrush, etc. Here is a list of error codes also
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #4 of 17 (permalink) Old 08-09-2016, 04:07 PM Thread Starter
Biker Dash's Avatar
Been searching, and no luck on finding one for the Vulcan.
post #5 of 17 (permalink) Old 08-10-2016, 07:34 PM
dlars's Avatar
It's pretty simple to pull off the right hand cover and the throttle body is right there.......hold the butterfly open with something and clean away. You could make your own video.
iPod Connector
Manual Fan Switch
dlars is offline
post #6 of 17 (permalink) Old 08-10-2016, 07:38 PM Thread Starter
Biker Dash's Avatar
Actually, I will need to kidnap my roommate to help me with doing that. He'll run the camera while I do the cleaning job.
Question, that spray type throttlebody cleaner safe to use? I was thinking that stuff could be useful for the harder to reach spots.
post #7 of 17 (permalink) Old 08-11-2016, 04:24 AM
Peg
Peg's Avatar
I found an old aerosol can of Amsoil Power Foam in my workshop. I can't remember where I got that or what I intended to use it for at the time. It could have belonged to the young fella even... he's an aircraft engineer & left a lot of stuff behind during his last move out of home (as they all do).
It's mine now anyway, and it's been fantastic for the occasional scrub of a throttle body. Spray some in there, use an old toothbrush & some Q tips & clean rags. Comes up a treat.
Paul (Peg) Elliott
Peg is offline
post #8 of 17 (permalink) Old 08-11-2016, 01:21 PM
dlars's Avatar
Ditto what he said. I use the wif........er, I mean an old toothbrush and some seafoam or other type of fuel stabilizer/carb cleaner. It's surprising the difference it makes just doing that once in a while
iPod Connector
Manual Fan Switch
dlars is offline
post #9 of 17 (permalink) Old 08-11-2016, 03:06 PM Thread Starter
Biker Dash's Avatar
Excellemt! I will look for that stuff. (I have a habit of trusting stuff others have had positive experience with)
post #10 of 17 (permalink) Old 08-13-2016, 06:33 PM
This might be a silly question. I see the throttle butterflies upon opening the right side cover, however I can't seem to open them manually. I'm afraid if I use a screwdriver to push them open I might damage something. But when the bike is on, the flaps open and close by turning the handle bar throttle. Am I just being chicken? Can I just spray some carb/throttle cleaner in there?
007chacoy is offline
Error code 14 and engine revs around 4Krpm gkalyanapu Vulcan 1700 3 04-06-2017 01:53 PM
Error code 18 and wiring Biker Dash Vulcan 1700 27 10-26-2016 06:01 PM
Tips for cleaning throttle bodies Diamond Jim Vulcan 2000 7 10-18-2013 07:19 PM
Error code 21 chipnrider Vulcan 1700 6 04-07-2012 09:28 PM
Error code after ECU replacement bpro215 Vulcan 1700 10 08-30-2011 06:33 PM
