87 or 90 octane with a PCV? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 08-01-2016, 11:16 PM Thread Starter
SilverT's Avatar
Year/Make/Model: 2016 Vaquero; 2003 Honda VTX
Displacement/CC's: 1700, 1800
Color: White Vaquero, custom VTX
All stock 2016 Vaquero. Marbled pair valve. Set PCV to Dynjet 005 stock Vaquero map and added addition fuel (+20 to +30) to zero and #2 throttle column between 1,500 and 2,250 rpm trying to reduce decal popping which happens most when letting off in 3rd and it hits under 2,000 rpm. Not perfect but MUCH better. Question: will the adding of extra fuel help in using 87 octane. The stock map from Dynojet adds additional across all ranges as well. Wasn't sure if this would allow for lowering octane level or should I still use the 90 recommended by Mfg. Some use 87 some use 93, I'm confused. Does the PCV change this? Thanks!!!
SilverT is offline
post #2 of 9 (permalink) Old 08-02-2016, 12:45 AM
davidsheek's Avatar
I would say adding a PCV would not change what octane to use.
I use 87 with my PCV and have been for years.
davidsheek is offline
post #3 of 9 (permalink) Old 08-02-2016, 12:36 PM
rick's Avatar
2012 Voyager, drilled baffles, stock intake, and a Gman controller. Have ran 87 since the 1st service was done, added the controller about 4 months later. Have only heard the valves twice and both time, I was letting the clutch out too quick and not giving enough gas. Bike now has about 53k miles. I dont ride it too hard. You can try a tank or 2, and decide yourself. If it pings, go back up in octane.
2005 800 classic
2012 Voyager ABS
rick is offline
post #4 of 9 (permalink) Old 08-02-2016, 12:36 PM
dlars's Avatar
Yup, I've been using 87 also.....no issues. All the PCV does is add or subtract fuel, it has no effect on fuel octane requirements that I'm aware of......but I'm no expert :-)
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #5 of 9 (permalink) Old 08-02-2016, 01:24 PM Thread Starter
SilverT's Avatar
Thanks! I'll try 87 for a while and see how she does. Just trying to help reduce the decel popping. Seems to pop more using 93 octane
SilverT is offline
post #6 of 9 (permalink) Old 08-02-2016, 01:34 PM
davidsheek's Avatar
Now there are other factors that can cause popping.
Like loose exhaust pipes at the head. Or a leak behind the throttle body to the port. There's a gasket for that.
And of course too lean of fuel.
post #7 of 9 (permalink) Old 08-02-2016, 01:49 PM
dlars's Avatar
Octane rating doesn't cause popping, Just like David says, a leak on your exhaust, or on the intake itself will cause it. When you decel it will still suck in air from the outside from anywhere there is a leak. Try using a cigarette or something that makes significant smoke and hold it by each head pipe where it bolts on with the engine running. If there is a leak you will see it. The Thunder Manufacturing gasket is a good idea also. Tuning is the only way to get rid of popping once all air leaks are eliminated. I've eliminated most of mine but what is left I'm used to it :-)
iPod Connector
Manual Fan Switch
dlars is offline
post #8 of 9 (permalink) Old 08-02-2016, 03:20 PM Thread Starter
SilverT's Avatar
Got rid of most of it. I did put on the TB gasket and washers behind the exhaust bolts. Did not do a smoke test. That's not a bad idea. I'll try and see how she looks. Added quit a bit of fuel, up to +30 round the 2,000 rpm mark, still playing with it. May take it to a dyno to see what they can do, or just have to live with what is left. Just don't want to screw things up by making to many guess changes on the PCV.
SilverT is offline
post #9 of 9 (permalink) Old 08-03-2016, 07:09 AM
captj3's Avatar
Sell the PCV and get your ecu flashed from Ivan. It will get rid of all the bad habits kawasaki put in the tune and you will have zero backfiring. Downside is you have to run 91oct or higher because he bumps up the timing on the lower end amongst other things. The bike will run great and cooler as well. Well worth doing. Just check all the reviews of people the have done it, not a bad word about it.
2012 Vaquero Candy Lime Green/Black
1700 Nomad (Deceased)
Cobra Tri-Oval Exhaust
Racnrays Invention (Throttle Mod)
Ivan's Flash
Thunder Tornado Air Kit
captj3 is offline
Running 87 octane gas? Spinillo Vulcan 2000 41 08-01-2014 01:25 AM
Octane at 90? Chicago_Cheech Vulcan 1700 27 07-19-2013 07:08 PM
80/90-21 vs 90/90-21 ceb2216 Vulcan 900 8 07-19-2011 05:40 PM
87,89 or 90+ octane for 2009 Classic LT guitpic Vulcan 900 13 08-20-2009 06:13 PM
1600 90 octane or better jvw9569 Vulcan 1600 6 06-06-2009 09:25 PM
