Air in Shocks - Kawasaki Vulcan Forum : Vulcan Forums
 4Likes
post #1 of 16 (permalink) Old 07-30-2016, 04:56 PM Thread Starter
Year/Make/Model: 2015 Kawasaki Voyager
Color: Charcole Gray
Air in Shocks
How much air should be in the shocks for a motorcycle that has a 375 lb load. Going on a long run and want everything to be as good as I can get it. Bike is a 2015 Voyager ABS.
sailorman3 is offline
post #2 of 16 (permalink) Old 07-30-2016, 05:43 PM
WEG
WEG is offline
post #3 of 16 (permalink) Old 08-01-2016, 05:48 PM Thread Starter
The manual say's not to use a tire gauge. What other kind is there?
post #4 of 16 (permalink) Old 08-01-2016, 08:11 PM
Year/Make/Model: 2016 Vaquero
MADTIME is offline
post #5 of 16 (permalink) Old 08-01-2016, 08:20 PM
TS Tinker's Avatar
You need a zero loss pump with a built in gauge.If you have a high end bicycle shop near you they should have one cheaper than you can find at any motorcycle shop. Most folks have theirs set between 25 and 30 psi. I run 26 myself(260lb) but almost never ride two up. "DO NOT" try to fill them with a regular air compressor! The chambers are so small, I am told about the size of a golf ball,you can easily damage them. A hand pump is the way to go.
10 Voyager
01 1500 Drifter
VRA Central Alabama Chapter 1-61
TS Tinker is offline
post #6 of 16 (permalink) Old 08-01-2016, 08:22 PM
TS Tinker's Avatar
Originally Posted by MADTIME View Post
I need to learn how to type faster
MADTIME likes this.
10 Voyager
01 1500 Drifter
post #7 of 16 (permalink) Old 08-02-2016, 02:55 PM
Originally Posted by WEG View Post
I don't recall seeing this previously but its almost spot on to what I have my Voyager at. I'm set a III with 12PSI in each shock for 235lbs.
Gary
SW Michigan
2009 Kawasaki Voyager
GGB6259 is offline
post #8 of 16 (permalink) Old 08-02-2016, 05:27 PM Thread Starter
So I bought a zero loss pump today. Its a Harley Davidson pump but that's what was out there for me to buy. I checked the shocks and they had zero air pressure in them. I pumped them up to 20 lbs and left the bike sit for 4 hours, Rechecked, and still 20 lbs. I'm pissed because when I bought the bike I asked how much air was in the shocks because I usually ride 2 up. They told me that's how it was set up. Does the bike come from the factory with no air in the shocks? I was wondering why I was hitting hard. I hope the bike is not damaged. I now have them set at 45 lbs each because with both of us on the bike the load will be 350 lbs. I'm the bulk of that.lol I also have the dampening set at 4 so I'll see how that goes.
post #9 of 16 (permalink) Old 08-02-2016, 08:07 PM
WEG
Hi SM3
My '09 V1700 Classic came with zero psi. I'm a lightweight 170 or so, maybe 190 with junk in he bags, I'm running about 7-8 psi set at 1. Don't know if this is best or poor or just OK. Runs and feels OK to me ��
WEG
WEG is offline
post #10 of 16 (permalink) Old 08-02-2016, 09:49 PM
TS Tinker's Avatar
45lbs is at or over the maximum pressure for the shocks.They are very expensive to replace. From what I have heard the dealer almost never airs up the shocks on delivery.
10 Voyager
01 1500 Drifter
adjusting air shocks on a 1500 classic? BigB General Vulcan Talk 2 07-12-2009 10:31 PM
Jack under Engine to Fill the Air Shocks? meanstreaker Vulcan 1600 8 11-27-2008 06:15 AM
