Decel popping on 2106 Vaquero - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-23-2016, 07:47 PM Thread Starter
SilverT's Avatar
Year/Make/Model: 2016 Vaquero; 2003 Honda VTX
Displacement/CC's: 1700, 1800
Color: White Vaquero, custom VTX
Ok, need help. Stock Bike. Dealer no help so I bought the PCV fuel manager no ignition, loaded stock Vaquero map from dynojet, installed TB gasket, marbled the reed valve hose and re-tightened the head pipe bolts. Still Decel popping when letting off the throttle. Also added +4 to the 0 throttle column on the PCV map. Any other suggestions? Should I maybe increase or decrease this value? Any suggestions would be greatly appreciated. Maybe better to use dynojet General map vs Vaquero map? Plan on keeping it stock as my VTX 1800 makes enough noise. Thanks to all in advance!
SilverT is offline
post #2 of 7 (permalink) Old 07-23-2016, 07:51 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Welcome in,like the white vaq
revrider is offline
post #3 of 7 (permalink) Old 07-23-2016, 08:09 PM
randog's Avatar
Year/Make/Model: 2014 Kawasaki Vaquero
Color: Orange
Get your ECU flashed by Ivan. You won't regret it.
Sent from my Nexus 6 using Tapatalk
2008 Suzuki M109R2
2014 Vaquero
Throttle Mod
Ivanized ECU
Vance and Hines Dual Slashed Slip-ons
Chuckster's BAK
Grasshopper Backrest
8" Windvest windshield
Power Port
MP3 Audio Adapter
Dual PIAA Horns
randog is offline
post #4 of 7 (permalink) Old 07-23-2016, 10:46 PM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
2nd for an Ivan Flash. It fixes so many issues beyond just richening the fuel mixture. My 15 runs SOOOOOO much better after the flash.
Ivan's Performance Products
D-Dub is offline
post #5 of 7 (permalink) Old 07-23-2016, 11:32 PM Thread Starter
SilverT's Avatar
Thanks! Good to know for the future. Just funds are low after paying for the bike, PCV, cost of dealer break in service and new helmet.
Hoping for other options for now. It's a shame you have to spend a fortune just to get a brand new bike to run right!
SilverT is offline
post #6 of 7 (permalink) Old 07-24-2016, 12:02 AM
hayes's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red|Silver
You'll never cure the decel pop, unless you get the Ivan's tune (or so I've heard). Honestly, live with it until you can get the tune. The tune is on my winter mods list. Stock pipes should keep it at a reasonable level.
I grabbed a fistful of throttle and all my worries disappeared.
|| Former President | Vulcan Riders Association | Chapter 1-30 ||
|| 2012 Kawasaki Nomad | EJK Fuel Controller | Vance & Hines Twin Slash Cut | Thunder Manufacturing BAK ||
hayes is offline
post #7 of 7 (permalink) Old 07-24-2016, 04:19 AM
Peg
Peg's Avatar
Ivan's flash is the only confirmed complete cure for the decel pop, and also cures many other rideability issues at the same time - so it's a shame you didn't get that advice before buying the PCV. But many of the rest of us have had our 1700's since before Ivan brought us his solution, and have tried various things to fix it. I had my EJK tuner running very well, and users of the PCV had best results using maps provided by member "davidsheek". Send him a PM... I'm sure he'd help you set it up.
It's odd that you're having pop with an otherwise stock bike though. Stock pipes usually mask the pop very effectively, and most reports of popping are with aftermarket pipes. There have been reports of intake air leaks on the engine side of the throttle body, rather than the airbox side, which may create symptoms similar to yours?
Paul (Peg) Elliott
Peg is offline
Buffles removed and popping on decel Need Dobeck or Cobra FI2000R diamondhill Vulcan 900 24 12-29-2012 10:23 AM
Popping on Decel. kettlinton Vulcan 1600 8 03-19-2012 08:13 PM
popping on decel booboo Vulcan 1700 1 03-03-2012 05:07 PM
Exhaust popping on Decel????? kettlinton Vulcan 1600 2 08-07-2011 04:03 PM
2009 Vulcan 1700 popping on decel Vman1700 Vulcan 1700 5 08-02-2011 07:30 PM
