PCV autotune question - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By cannonballs
post #1 of 8 (permalink) Old 04-29-2015, 10:07 AM Thread Starter
I got a PCV and autotune and am planning to install this weekend.
I have a 1700 classic with V&H big shots and thunder stock cover air kit.
2 questions I have is:
Where the ignition wires I have to connect to are located?
Do I have to drill the O2 sensor on the pipes or the V&H /VN1700 have that already I can just plug?
If I have to drill, do I need to sensors, one for each pipe and where should I drill?
Thanks all
grVN1700 is offline
post #2 of 8 (permalink) Old 04-29-2015, 01:18 PM
dlars's Avatar
The wires you have to connect the PCV are under the battery cover on the ECU. You tap into them using the posi-taps which are supplied. The PCV and auto-tune have pretty good instructions and pictures for the install if I am recalling correctly. I have the FPE true duals and I had to drill a hole about 12" from the cyl end of the head pipes for the O2 sensors prior to the pipe install. It depends on which auto-tune unit you received, if you have just the one sensor....one hole. If you're pipes aren't true duals, just try to get the O2 sensor installed in the pipe just before it splits off to each side. If you do a search on here about that, there is quite a bit of info and I believe someone posted close-up pictures of the wire install on his bike also. Here are a couple pictures of the sensor install I found on here:
Name:	O2 Sensor Placement.jpg
ID:	112729   Click image for larger version
Name:	O2 Sensor Placement2.jpg
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #3 of 8 (permalink) Old 04-29-2015, 01:24 PM
dlars's Avatar
Actually just found this thread. If you didn't get the PCV with ignition, just disregard that info. Just be sure to read it all through thoroughly and make sure you've got it straight before you start......good luck
https://www.vulcanforums.com/forums/s...ght=PCV+wiring
iPod Connector
Manual Fan Switch
dlars is offline
post #4 of 8 (permalink) Old 10-10-2015, 10:16 PM
rick's Avatar
Am thinking of getting this for my Voyager. Does the auto tune also adjust the timing if you get the pcv with ignition? I understand it does not actually change your map, but recommends changes you have to apply to the fuel, but havent seen anything about the ignition timing.
2005 800 classic
2012 Voyager ABS
rick is offline
post #5 of 8 (permalink) Old 10-11-2015, 04:29 PM
cannonballs's Avatar
hi rick
auto tune dosnot change the ign you have to set that your self.
you set a air fuel ratio and the auto tune will adjust the pcv to obtain that ratio ,and yes you have to accept those settings for them to remain.
it pays to reduce the amount of adjust the auto tune does mine is restriceted to + or - 2 as im very happy where it runs and only let if fine tune whiel i ride ,but i dont accept it as i like my map
2010 voyager
v/h performance pro pipe with quieter muffer
pcv with ign
individual gear mapping
auto tune
commander 11 rear tyre
2 inch risers
Allycat air intake
cannonballs is offline
post #6 of 8 (permalink) Old 10-11-2015, 10:43 PM
rick's Avatar
Thank you cannonballs. I already have a Gman/Bully controller, but understand that advancing the timing makes a big difference in performance and mpg also, the mpg being my main concern now since it seems to run pretty good as is. Did some reading here last night and saw a couple post about performance dropping due to the auto tune leaning the A/F too far.
2005 800 classic
2012 Voyager ABS
rick is offline
post #7 of 8 (permalink) Old 10-13-2015, 03:04 AM
yes auto tune can lean them out, if not set right .
you need your targeted air fuel right and you dont let the pcv loose with adjustment standard it can go + or - 10 settings, i only let it go +or- 2 and now dont accept any as im happy with my map so it can only fine tune it up or down 2 increments at a time
just to make it more confusing we have gone one further with individual gear mapping with different air fuel ratios for each gear
so power down low and fuel economy in 5th and 6th gears
hockeynut52 likes this.
2010 voyager
pcv with ign
auto tune
2 inch risers
Allycat air intake
post #8 of 8 (permalink) Old 10-22-2015, 12:35 PM
Wadegster's Avatar
Hi Cannonballs, would you mind sharing your map?
2010 Red/Black Voyager
Kawi QR backrest
iPod adapter
Kuryakyn ISO grips w/ RACNRAY's throttle mod
V&H slip-ons
PCV Fuel, Ignition and Dual Auto tune
Kurakyn Longhorn pegs
Thunder Mfg Odyssey Air Kit
Alpine KTP-445U AMP
Brewsters 6.5" speaker adapters
Infinity 612m 6.5" fronts
Polk Audio DB521 rears
Wadegster is offline
PCV, Autotune and trim question(s)! motomi1 Vulcan 1700 9 03-11-2014 08:37 AM
PCV Autotune Install bikesrfun Vulcan 1700 4 01-08-2012 11:38 PM
PCV Autotune Module RJH Vulcan 1700 1 05-11-2011 10:43 PM
Must Read! - PCV and the autotune Klemm05 Vulcan 2000 0 03-26-2011 11:43 AM
Caution With Pcv(5) Autotune Bytehead Vulcan 900 0 03-31-2010 02:03 AM
