Scary issue today with my throttle grip - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 04-25-2015, 03:53 PM Thread Starter
I would like to ask if this has happened to anyone before. While pushing my 1700 Nomad around my garage today, suddenly the throttle grip came loose and slid out near the end of the handlebar. I don't mean just the grip. I mean the entire sleeve moves out as far as the cables will allow. I nearly dropped the bike when this happened. When I slide it out of the housing, I can see the end of the sleeve has a notched black ring around the circumference. I can slide the sleeve back in and it kind of seats back in ,but it will slide right back out very easily. It's like something completely separated. I am glad this didn't happen on the road, and the bike is definitely not rideable. Can anyone suggest what this is all about? Did I break it when I was pushing the bike around?
Thanks in advance for any help, Eric
ridgeman06 is offline
post #2 of 7 (permalink) Old 04-25-2015, 04:24 PM
gv550's Avatar
I have a complete throttle grip in front of me (spare), it is a white plastic sleeve, inner chrome ring, black rubber grip, and chrome end cap. There is no notched black ring. Is yours a stock grip or aftermarket?
Garry
2009 Voyager ABS:
Sold at 679,465 kms
Improve handling, suspension and tire life
with Garry's Fork Brace.
gv550 is offline
post #3 of 7 (permalink) Old 04-25-2015, 04:58 PM
Peg
Peg's Avatar
It's hard to picture what you mean. Is the entire switchblock loose, so the whole throttle side assembly moves? There's a screw in the inner front, and a chrome cap on top, to keep that in place. It may just require tightening up.
Paul (Peg) Elliott
Peg is offline
post #4 of 7 (permalink) Old 04-25-2015, 06:43 PM Thread Starter
I have show chrome comfort heated grips. It must be the show chrome sleeve that is different from stock. Sorry about not specifying that. The whole sleeve assembly comes out of the housing. When I slide it outwards, I can see the notched end of the sleeve. It will slide back into the housing and lock in the notches so I can rotate the throttle. But it won't stay in. It will come right out and slide ont the handlebar a couple inches before the cables run out of slack.
If this happened out on the road, I probably would have crashed.
post #5 of 7 (permalink) Old 04-25-2015, 07:22 PM
Bubba in TX's Avatar
Sounds like something let loose for sure. Normally the glue job will come loose from the heat. I wouldn't trust it without taking it apart and having a good look. But almost any throttle sleeve will work on these. Kawasaki, Yamaha. Honda, Harley....
We had heated grips on our patrol scoots and the grips would always separate from the sleeve, but not the sleeve come out of the housing. I would even say that the show chrome sleeves are defective. Compare the show chrome cable stays with the stock grip.
A pic would help....
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #6 of 7 (permalink) Old 04-25-2015, 07:58 PM
gv550's Avatar
From your description it sounds like the switch housing has broke, allowing the sleeve to come loose. If the sleeve had broke the cables would not be coming out. As mentioned, a photo or 2 would really help........
Garry
2009 Voyager ABS:
Sold at 679,465 kms
gv550 is offline
post #7 of 7 (permalink) Old 04-26-2015, 05:48 AM Thread Starter
Thanks for the responses guys. It's hard to describe what happened. The whole grip sleeve is broken free from the housing.
Lucky for me, I saved my original throttle sleeve, so I am going to put it back on today.
The Showchrome grip is obviously defective
Help please with scary noise nascarguy67 Engine Work 3 04-05-2016 10:05 PM
Scary. . . Hound Dog Vulcan 1600 0 02-16-2015 04:21 PM
Scary Stuff! Blockhead General Vulcan Talk 4 04-13-2013 03:41 PM
Scary, read this letter from my Tx congresswoman bulldozer The Lounge (Off Topic) 8 09-09-2012 07:17 AM
Throttle Grip Adjustments vulcan2004 Vulcan 500 0 12-05-2010 09:00 PM
