clutch problem - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 25 (permalink) Old 03-23-2015, 09:27 AM Thread Starter
jimmyd1's Avatar
clutch problem
Dudes,
Needing more help. I got on my bike this morning started it backed it out of the barn and the clutch is rock hard. It was still dark so I haven;t been able to do any inspection yet. Rode Saturday and the operation was flawless. It's like it doesn't have any travel at all. Any ideas? I will chcek fluid levels when I get off but have a feeling something worse is happening.
Ride it like you rented it!
Jimmy D
1700 Classic
FP combat 2 into 1
PC V
Tsukayu jumbo hard strong
Cobra fatty hiway bars
Kury pegs
Grasshopper backrest
Bestem luggage rack
go cruise throttle lock
jimmyd1 is offline
post #2 of 25 (permalink) Old 03-23-2015, 10:33 AM
rick's Avatar
Have you every flushed the system? Sounds like may be dirt in the cylinder clogging a port. Would also lube the pivot point where the lever is attached. What year is it and how long have you had it?
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 25 (permalink) Old 03-23-2015, 11:07 AM Thread Starter
jimmyd1's Avatar
It's a 2010 classic with 18K on it. I bought it new (held over) 2 years ago.
last fall I was going to get a 15K service with all the vaccuming and replaceing the fluids and they said I was kinda' wasting money. The fluids were clear and full. I suppose pretty much setting through the winter may change things??
Jimmy D
1700 Classic
FP combat 2 into 1
PC V
Kury pegs
Bestem luggage rack
jimmyd1 is offline
post #4 of 25 (permalink) Old 03-23-2015, 11:15 AM
Similar thing happened to mine. Took the slave cylinder out and it was full of grit and dirt. Cleaned it all out, re-lubed it with hydraulic specific grease and it's fine now. I'm not saying yours will be the same but I'd start there as it's easy.
2005 Harley Davidson Road King
2015 Harley Davidson Softail Deluxe
Keef is offline
post #5 of 25 (permalink) Old 03-23-2015, 12:50 PM
dlars's Avatar
Ya, what he said. The slave cylinder piston could be gummed up and sticking. If you're not sure about removing it just shoot me a personal message and I'll send you the instructions from my service manual. I've removed mine and it's very simple.
barnysanchez likes this.
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #6 of 25 (permalink) Old 03-23-2015, 01:31 PM
Peg
Peg's Avatar
I've had the same thing happen after a long trip on unsealed roads recently. A short trip around town the next day saw me stall the bike in first gear to stop it, after a car pulled out of a park in front of me and the clutch lever wouldn't budge. It's a poor design when all that dirt & grit gets thrown at and sticks to the clutch pushrod - it doesn't take much to jam it.
I had to remove the front pulley cover, pull the rod, and clean it all up. Fixed the problem immediately. Don't leave any grease on the exposed portion of the rod when you re-assemble, or grit will stick to it again.
Paul (Peg) Elliott
Peg is offline
post #7 of 25 (permalink) Old 03-23-2015, 08:20 PM
TS Tinker's Avatar
I had a crazy clutch day last fall.
Rode the Voyager to work 25 miles surface and interstate. No problems.
That afternoon start the bike pull in the clutch hit the shifter to 1st bike lurches forward hit the breaks bike dies. Round 2 same thing. Get off look everything over round 3 same thing. Basically direct drive no clutch.
Not my 1st rodeo, the bike got me here, it is still running, no ridiculous noises coming out of it, it will get me home.
In gear start. Not as hard as it sounds. All of my 90's boats were set up this way, illegal as hell, but if you were pushing some hp a good way to save wear on gears in the lower unit.
I was able to get the bike home with only 3 in gear starts. Up shifts are easy without a clutch just pre-load and let off on the gas. Down shifts are a little more complicated but doable.
After getting the bike home before doing anything I bled the master cylinder.
1st round flat as a pancake
2nd round some pressure
3rd round full pressure.
So what happened on that day while I was at work to make the clutch slave cylinder fail? I have no clue, but I do have break fluid a tube and a wrench to fit the bleeder valve in my saddle bag as we speak.
10 Voyager
01 1500 Drifter
VRA Central Alabama Chapter 1-61
TS Tinker is offline
post #8 of 25 (permalink) Old 03-24-2015, 04:54 AM Thread Starter
jimmyd1's Avatar
When I got home it pulled the clutch lever and it actually moved about 1/2 way. Released and pulled it again and it was fine. I actually rode it a bit just to be sure. I will be taking it to the shop today. I'll let you know what the issue is.
I live on about a 1/2 mile of bad gravel and its probably crudded up.
Will advise.
Thanks everybody,
Jimmy D
Jimmy D
1700 Classic
FP combat 2 into 1
PC V
Kury pegs
Bestem luggage rack
jimmyd1 is offline
post #9 of 25 (permalink) Old 03-24-2015, 01:22 PM
Peg
Peg's Avatar
Easy to check yourself... Take the pulley outer cover off, tie in the clutch lever & take the clutch slave assembly off, take the pulley inner cover off, pull the clutch pushrod out, wipe all the gunk off it... reverse the procedure.
Sounds like you've had the same problem I did. It'll work mostly, but get jammed when you least want it to.
Paul (Peg) Elliott
Peg is offline
post #10 of 25 (permalink) Old 03-24-2015, 02:44 PM
No need to tie the clutch lever in.
Just pull the slave cylinder and clean all the crud out.
Keef is offline
Clutch Cable or Clutch Problem? 59Vulcan Vulcan 2000 8 12-27-2015 07:40 PM
Clutch Cable or Clutch Problem? 59Vulcan New Member Introductions 1 12-22-2015 02:46 PM
Fuel Tap Problem - Petcock Problem Brewster_440 Vulcan 800 0 04-11-2014 08:46 PM
Stalling Problem? - Maybe you have a Cosmic Ray problem in your area myVoyager1700 Vulcan 1700 1 07-30-2010 02:29 PM
Overhearing Problem? Maybe No Problem at All? QJC Oil and Lubrication 4 10-26-2009 06:38 AM
