Strange Noise - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 03-21-2015, 02:45 PM Thread Starter
Strange Noise
Tried searching but did not find anything that seemed to be similar. Hopefully this sets off bells and y'all can tell me I am a dumb ass for not finding it as there are a million posts. Anyway,.....
2010 Voyager with 17,700 on her. I have only riden a few miles and notice when I get home from work (about 8 miles in town ride) and shut her off I have a high pitched whining type sound from the front end. Sound like up under tank maybe. The sound resembles a warning buzzer of sorts but everything is off. My second thought was some kinda sound from cooling system maybe pressure with a slight leak or something. I dunno I am lost and hoping it is some common thing that a noobe would not realize.
Sodapop is offline
post #2 of 11 (permalink) Old 03-21-2015, 05:41 PM
dlars's Avatar
I'm betting it's the tank venting. Next time you stop and hear it, pop the gas cap open and see if it stops. My 1500 Classic did it too......normal
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #3 of 11 (permalink) Old 03-21-2015, 05:43 PM Thread Starter
Originally Posted by dlars View Post
It's the tank venting. Next time you stop and hear it, pop the gas cap open and see if it stops. My 1500 Classic did it too......normal
Good to know. I figured it was likely some normal thing for the bike since I only noticed it after I stopped and shut the bike off.
Sodapop is offline
post #4 of 11 (permalink) Old 03-21-2015, 06:38 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Hey sodapop,1700 nomad here,went for a ride,pulled in garage,heard same kind of sound you have,think its normal
revrider is offline
post #5 of 11 (permalink) Old 03-21-2015, 07:51 PM
rick's Avatar
You should hear my 800 in the summer time, it whistles so loud ,girls turn to see who it is. Its normal, do as Dlars says above.
2005 800 classic
2012 Voyager ABS
rick is offline
post #6 of 11 (permalink) Old 03-25-2015, 03:06 PM
The sound you are probably hearing is the same sound I have and everyone of these bikes have. When the 1700 is shut off the throttle plates return to a closed position. Oh, I am not an expert or a mech., but I wondered myself what it was buzzing under the tank so I took the right side cover off and seen this positioning take placed. Next time before you start your bike up just turn on ignition. Let it go thru the normal check, then turn key off. You should here the plates reposition themselves.
I don't hear it as much when I am outside of the garage. I hope this helps. It could be the vent, but I have never heard my whistling like I did from the 1500 I had before this one.
bpro215 is offline
post #7 of 11 (permalink) Old 03-25-2015, 03:31 PM
Money on tank vents. Two lines one on rear bottom, each side of the tank. Probably pinched. Should be fairly loose dropping down towards the bottom and rear...
Gary
SW Michigan
2009 Kawasaki Voyager
GGB6259 is offline
post #8 of 11 (permalink) Old 03-25-2015, 06:15 PM Thread Starter
Was out riding a bot today and when I got home I heard it a few minutes after I shut down. I opened gas cap and poof, all gone. So def was the tank vent. Thanks for the replies.
Sodapop
Life moves pretty fast, if you don't stop and look around once in a while you could miss it.
Sodapop is offline
post #9 of 11 (permalink) Old 03-25-2015, 07:26 PM
shepsvoyager's Avatar
My 06 nomad whistled all the time too. Gas gap. I have never heard the voyager do this, but, i also went deaf in 1 ear just after I got the Voyager. HMMMM!!! LOL.
shepsvoyager is offline
post #10 of 11 (permalink) Old 03-25-2015, 07:42 PM
Yep, tank whistle.
VulcanDrifter is offline
Strange Noise XSXLR8R Vulcan 2000 48 08-19-2014 04:50 AM
strange noise special K Vulcan 1700 24 01-12-2012 06:06 PM
strange noise in exhaust dthom74 Vulcan 800 2 07-26-2011 08:44 PM
Strange noise Cleanevo Vulcan 800 8 07-12-2011 09:54 PM
Strange Noise from front lower portion of Motor dkurth General Vulcan Talk 0 05-20-2010 09:15 AM
