cobra slipons - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-07-2015, 02:07 PM Thread Starter
cobra slipons
I ride a 2012 vaquero just put cobra slipons on and now I'm getting back firing. Any recommendations on a fuel controller, programmable or not programmable?
stephanie is offline
post #2 of 7 (permalink) Old 03-07-2015, 02:16 PM
Kap
Kap's Avatar
Standing by for an answer on this one. I just purchased the Cobra slip-ons as well (not yet installed) and wonder if a fuel controller is really needed?
Kap
2010 Classic LT - Imperial Red & Metallic Titanium ("
Friends tell me I need to get in shape. Round is a shape, isn't it?
Kap is offline
post #3 of 7 (permalink) Old 03-07-2015, 02:19 PM
RACNRAY's Avatar
Skip he programmer for now.
This is what MUST be done at the same time s/ons are installed. The fresh air intake system (kawi calls it the "kleen" system, Suzuki calls it the "pair' system)brings fresh air into the exhaust ports for emission reduction. This system is largely responsible for the popping outa the exhaust and must be rendered inoperable.
Take the right side air box cover off, 4 small allen head bolts and it's off. Look at the black back part of the air box, look at the 11 oclock position, you will see a hole. This hole needs to be plugged up. A quickie method is to fill that hole with a high temp silicone like ultra black, ultra grey, etc. Allow time for full cure before starting.
This will reduce the popping, what percentage varies between bikes and types of s/ons.
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #4 of 7 (permalink) Old 03-07-2015, 02:53 PM Thread Starter
Thanks I'll try that.
post #5 of 7 (permalink) Old 03-07-2015, 06:05 PM
rick's Avatar
RACNRAY
Doesnt the hose that goes there also need to be plugged, or do you just plug the hole and reconnect the hose, effectively plugging the hose at the same time?
2005 800 classic
2012 Voyager ABS
rick is offline
post #6 of 7 (permalink) Old 03-07-2015, 06:12 PM Thread Starter
So tried that and no change still back fires. So I'm guess I'm going to have to suck it up and going to buy the power commander V.
post #7 of 7 (permalink) Old 03-07-2015, 09:27 PM
Send a message via AIM to tmanv2krider
Sure you're not just getting decel pop? Decel pop can be tuned out but it's not necessarily a bad thing. A properly tuned hot rod HD should have a little decel pop, and I see no reason why an overhead cam metric should be any different.
1996 Harley Davidson FXDS with a lot of stuff. Yes, it's fast, yes it will pull the front tire in 1-3rd. No it's not a stock evo.
2011 Vulcan 1700 Vaquero
tmanv2krider is offline
cobra slipons nickman_33 Vulcan 1700 2 10-06-2012 04:46 PM
Cobra Slipons Eric Vulcan 1700 4 03-05-2011 03:00 PM
concerned about slipons! Eric Vulcan 1700 1 10-19-2010 07:38 PM
V2000 RoadHouse Slipons V2000 Bikes For Sale 1 08-31-2010 05:15 AM
slipons harpdad Vulcan 900 2 06-14-2009 08:29 PM
