DIY air cleaner question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 30 (permalink) Old 02-06-2015, 07:33 PM Thread Starter
Im way too cheap to buy the thunder 51010 stock cover kit so I'm wanting to make it instead. The question I have is what are the dimensions of the air filter. I'm hoping it's either a standard harley part or a 6-3/8" automotive size. Also, I've heard of complaints with metal backing plates on big air kits due to heat soaking of the temp sensor so I'm going to try some 1/4" lexan instead. Thanks for any input guys.
vaquerojon is offline
post #2 of 30 (permalink) Old 02-06-2015, 07:54 PM
Damn! you are a cheap ass. Lexan??? really ?? It'll crack..... Never work. There is a reason guys make these from aluminum or steel....
MT Buckeye is offline
post #3 of 30 (permalink) Old 02-06-2015, 08:24 PM
I am very sure lexan will not crack... but it will flex. I believe it would make good prototyping material if you have a supply of it, I use it often partially because of it's transparency
New to me 2009 Nomad
markdavidson is offline
post #4 of 30 (permalink) Old 02-06-2015, 09:13 PM Thread Starter
I'm thinking of a plastic vs metal because of the lack of heat transfer. Lexan actually costs just as much as aluminum. I don't have anything against store bought parts I just like to get the most hp for the dollar.
post #5 of 30 (permalink) Old 02-06-2015, 10:02 PM
twowheeladdict's Avatar
You bought the wrong bike then.
Way less expensive bike out there with higher horsepower to weight ratios.
twowheeladdict is offline
post #6 of 30 (permalink) Old 02-06-2015, 10:53 PM
Bubba in TX's Avatar
I know a guy that made a air filter housing for a Yamaha with a 10 inch aluminum frying pan/skillet. Even left the handle on it....
Compared to all the other crazy crap he had on it, it did not look out of place... he also used galvanized pipe for exhaust pipes.
But having used assorted plastics for a lot of projects.... I would worry about the heat my Voyager gives off from the head regions. BUt depending on the "blend" of plastic you use... if you are good at creating, you could make a really unique air filter box... almost as good as a frying pan..........
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #7 of 30 (permalink) Old 02-07-2015, 06:13 AM Thread Starter
I would like to get the same material they used for the factory box but I don't think you can just go to walmart and find a sheet of that stuff. Lexan is decently temperature tolerant but it breaks down when you hit it with petroleum I might just have to break down and do it with aluminum and try relocating the sensor before I drill a spot for it on the plate.
post #8 of 30 (permalink) Old 02-07-2015, 06:18 AM Thread Starter
As far as the wrong bike, I've had most of the other types. I know this will never be fast but it could at least have a muscular 0-60 hustle and be less of an EPA turd. If I can get the engine even close to feeling like my stock Victory Vegas did I will be pleased.
post #9 of 30 (permalink) Old 02-07-2015, 06:53 AM
Vulcan Hammer's Avatar
Send a message via AIM to Vulcan Hammer Send a message via Skype™ to Vulcan Hammer
Lexan also does not like Loctite (or other thread locker products). The Loctite migrates through the Lexan as if it were a sponge and then the Lexan crumbles into tiny fragments...I learned that expensive lesson some time ago.
Vulcan Hammer is offline
post #10 of 30 (permalink) Old 02-07-2015, 07:28 AM
Peg
Peg's Avatar
I imagine that would have been useful on camping trips?
Paul (Peg) Elliott
Peg is offline
Chrome HD Air Cleaner Insert for VN900 Air Box Cover Mod RickD Bike Parts, exhausts, etc. For Sale 2 09-12-2014 09:27 AM
Air pops from air cleaner 02 classic cijiwij Vulcan 800 8 04-11-2012 08:14 PM
