PCV issue - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 02-05-2015, 12:01 PM Thread Starter
PCV issue
I have just fitted a new PC V to my 1700 Nomad. When I turn on the ignition, the red warning light flashes, and ERR11 appears on the instrument console and the bike won't start. I have double checked my installation aginst the wiring instructions and can't see any faults. The green Power light on the PCV only stays on for about 3 seconds, as does the status light, then both go out. Looks like it could be a fault with the unit and I am awaiting a response from Dynojet Support team. In the meantime, has anyone experienced this and have any ideas?
Thnx
Barnowl is offline
post #2 of 3 (permalink) Old 02-05-2015, 03:42 PM
RACNRAY's Avatar
I am assuming there were no problems with this skoot b4 the installation?
Error code 11 relates to "throttle position sensor". The PCV has a wire that is connected to a wire at the throttle body, that is one of the wires for the tps .
Either that connection is not good or the connector has split the copper wires and opened that circuit...I just sent back a brand new outa the box pcv to d/j. Bike didn't sound right at start up and had abnormal glitches/hesitations at different rpm/throttle positions. Completely disconnecting the pcv allowed the skoot to run properly.
Make sure you have the correct PCV, make sure it has the latest firmware. The "remove the pcv and see if that fixes the problem" is also recommended.
GOOD LUCK
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #3 of 3 (permalink) Old 02-05-2015, 04:53 PM Thread Starter
Hi, thanks for your reply. I have spoken to Dynojet and it looks like I have not fitted the Posi-tap connections correctly. I haven't used these before so will have try again.
Barnowl is offline
air cleaner issue/ cooling issue related?? help!! dseptshun Vulcan 800 16 07-13-2012 07:25 AM
VN900 Debaffle + Hypercharger.. PCV Map? Switch420 Vulcan 900 8 02-27-2011 08:19 PM
Help--- PCV - HK Strippers - Hypercharger = Which map? dutchinc Vulcan 900 3 04-24-2010 08:24 AM
Caution With Pcv(5) Autotune Bytehead Vulcan 900 0 03-31-2010 02:03 AM
