Bike died twice over 5 weeks - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 12-01-2014, 04:08 AM Thread Starter
Dozrtravlin's Avatar
Twice in the past 5 weeks the motor has just stopped and won't restart for about 3-5 minutes. No warning, no error codes, guages all good - nothing. all appears normal but won't turn over. If I turn the ignition on and off all start up sequences work and all fuses check out. Engine not overheating just normal around town riding.
If I leave the key off for a few minutes then turn it on again the starter fires and away we go no issue
My thoughts are
Kill switch
Man Down
2009 Voyager, "Battle Star"
SageBrush Bib,
LED's around Headlight,
Chrome cup holders,
Marvellas passenger and rider highway pegs,
Grasshoper backrest,
Kawasaki Gel seats,
Grey Sheepskin Seat covers,
Kawasaki Rear Speakers,
Ipod Kit,
H.D. trunk rack,
Chrome passenger board covers,
Chrome Engine plate,
Door Controller,
Fog Lights wired to High Beam on/off.
Speedo Healer, Backoff Brake Module
KAM's heat kit
BLue Knights BKAUS11 and
BlueLiners Australia
Ride with Pride
Dozrtravlin is offline
post #2 of 6 (permalink) Old 12-01-2014, 05:06 AM
more likely the side stand switch, more easily contaminated with road crud etc.
give it a good dosing of WD40 to clean any crap out of it.
Damn intermittent faults are so hard to find.
2005 Harley Davidson Road King
2015 Harley Davidson Softail Deluxe
Keef is offline
post #3 of 6 (permalink) Old 12-01-2014, 11:38 AM
rick's Avatar
The 09s and 10s had a recall for the ECU for this kind of thing. Do you know if its been done on yours? Also check for the broken wire from the ignition under the tank, another known issue. Check out the links below.
[url]https://www.vulcanforums.com/forums/showthread.php?t=11997
https://www.vulcanforums.com/forums/showthread.php?t=62009
2005 800 classic
2012 Voyager ABS
rick is offline
post #4 of 6 (permalink) Old 12-01-2014, 04:36 PM Thread Starter
Just replaced the side stand switch about a month ago. but will give it a clean Yes the ECU has been done.
SageBrush Bib,
Chrome cup holders,
Kawasaki Gel seats,
Ipod Kit,
H.D. trunk rack,
Door Controller,
KAM's heat kit
Ride with Pride
post #5 of 6 (permalink) Old 12-01-2014, 05:08 PM
Last year I had a similar issue where the bike would die for no reason. As if someone hit the kill switch. What I did was take the kill switch apart and spray the contacts with some carb cleaner. Since then I haven't had an issue. But I've also stopped using the kill switch to shut the bike off. I just use the kick stand.
imac convert is offline
post #6 of 6 (permalink) Old 12-01-2014, 05:19 PM Thread Starter
Same thing and I took the switch off yesterday and sprayed it so I hope that's all it is. I normally don't go near the kill switch either but when I think back I used the kill switch for some reason when it happened the first time
SageBrush Bib,
Chrome cup holders,
Kawasaki Gel seats,
Ipod Kit,
H.D. trunk rack,
Door Controller,
KAM's heat kit
Ride with Pride
It's not even half the hp and twice as fun Kahres05 Vulcan 650 S 30 01-15-2018 05:11 PM
Bottomed out twice now need advice tonebob Vulcan 1500 22 06-21-2012 11:47 AM
having to pay for something twice loveriding General Vulcan Talk 10 04-08-2010 08:18 PM
bike stored 3 weeks, not starting mimizone Vulcan 500 3 10-06-2009 04:32 PM
