Winter Storing - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 11-26-2014, 05:34 PM Thread Starter
Winter Storing
Just got my 2011 Nomad 1700 delivered, now sitting in my unheated garage. The owner's manual says to take out the battery and keep indoors. Then on the other pages it showed that batteries discharge faster on warmer temp. and stays pretty much 100 percent when cold. My garage temp. goes down to 5- 7c but never below 0. I probably wont be riding until sometime April next year, unless of course we get a break and get a dry sunny day from this wintry weather. Would a battery tender hooked up the whole time ok? It also said on the manual that if the bike is left sitting for a few months, just the clock which is constantly running can drain the battery.
Any advise from experienced Nomad owners? Thanks.
007chacoy is offline
post #2 of 6 (permalink) Old 11-26-2014, 09:54 PM
Year/Make/Model: 2013 Voyager
Color: Pearl White/Titanium
Not a Nomad owner but right now we have 3 Vulcans in my unheated garage 99-800a, 02-1500 mean streak, 2013 voyager ALL plugged into Battery Tender brand maintainers. In the basement on Battery Tenders are the batteries for the boat and camper. Been using these maintainers for about five years now and the only problem I've ever had is when my son doesn't plug his in and it sits too long most of the time we plug it in and over night it's ready to go I like the fact that the lights on the maintainer tells you it doing its job
MidIAVoyager is offline
post #3 of 6 (permalink) Old 11-26-2014, 11:19 PM
chromedome195's Avatar
Year/Make/Model: 1990 Kawasaki Vulcan 500
Displacement/CC's: 500
Color: Red
Plus 1 on the battery tender. It's fine to leave it hooked up all winter long---in fact---
recommended!
1999 Suzuki GZ250
2004 VStar 650
chromedome195 is offline
post #4 of 6 (permalink) Old 11-27-2014, 09:10 AM Thread Starter
Red face
How much amp recommended for the tender? Mine is a 2A maintainer with a power light and a charging light. The charging light goes off as soon as the battery reaches 100%. The manual says the small cable on the side of the bike is for accessories. Is this where you hook up the charger? The end plug looks similar. This is the first winter this bike will sit in my unheated garage. By the way, if you unhook the whole battery, would that affect the meters' datas: like clock, rpm, odometer, etc? Do you have to set these all up again when you put the battery back in the summer? Thanks again for all your inputs. Much appreciated.
post #5 of 6 (permalink) Old 11-27-2014, 10:38 AM
Jammin'John's Avatar
2 a max. Less is better.
yes
JJ
'97 Valkyrie Tourer '06 Stratoliner Midnight '09 V2KLT
NOT a member of an organized religion
Jammin'John is offline
post #6 of 6 (permalink) Old 11-27-2014, 11:08 AM
Unhooking and/or removing battery will effect the clock but will not effect odometer, speedo. Just make sure you are using a battery maintainer NOT a trickle charger. The difference being a trickle charger will not self regulate the amperage needed to maintain a charge it will continue to charge and eventually overheat the battery and boil it dry effectively overcharging the battery and rendering it useless... batterytender.com for info and the cheapest place I have found is Batteries Plus
Storing for the winter Cheesefood New Riders 23 10-13-2012 09:36 PM
storing for winter ? bikerchik General Vulcan Talk 6 11-28-2010 10:05 PM
Storing bike for winter. baxter Vulcan 1700 2 10-01-2009 12:11 AM
Storing my Vulcan 900 Classic LT for the first winter Merasheen Vulcan 900 3 11-02-2008 02:03 PM
Storing Vulcan 900 classic for the winter??? Merasheen General Vulcan Talk 1 09-18-2008 11:33 AM
