Nomad buyer needs advice. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 11-11-2014, 02:11 PM Thread Starter
Hi all, I'm looking to buy a 2009 Nomad with about 6k on the clock. I have seen the thread re- under tank wire chaffing, but are there any other issues to consider ? I've also heard that gear change can be 'clunky', is this excessive?
Any other advice would be appreciated.
Thank you in advance.
Barnowl is offline
post #2 of 6 (permalink) Old 11-11-2014, 06:23 PM
archer2's Avatar
The gear change clunk, I think, is a built-in thing on most all the 1700 tranys from what I've read about it. have a 2014 1700 Voyager with just over 1000 miles on it and shifting from 1st to second when cold is a bit clunky.
You'll soon get used to it when you've ridden it a while or really fast when you power through the other gears.
2014 Kawasaki 1700 Vulcan Voyager ABS
Sena 20S Bluetooth Communication
RACNRAY throttle mod w/ISO grips
Shark Evoline Series 3 Helmet
Dually ISO highway pegs
34024-1330 Kickstand
Kawi Front fender rails
Kawi Ipod adapter kit
Kawi Lower bag rails
Super Lizard lights
Kawi Top bag rails
USB Adapter
Metzeler 180/65B16 81H rear tire
Drilled baffle plates
2012 Kawasaki Vulcan 900 Classic LT (sold)
archer2 is offline
post #3 of 6 (permalink) Old 11-11-2014, 07:17 PM
twowheeladdict's Avatar
If it is the red and beige Nomad, you are getting the best color produced. I had one for 6 months. Bought it in '11 and couldn't get used to the speedo on the tank.
The clunk can be minimized by short shifting from 1st to 2nd. It is just a clunk, no a grind so no worries.
Take it for a ride and make sure everything works including the cruise.
twowheeladdict is offline
post #4 of 6 (permalink) Old 11-12-2014, 07:51 AM Thread Starter
Yes, it is the Red & Beige.
I had a Honda FC Valcrie which was also clunky. Honda stated that due to the torque on a big engine going thro' the gear box, the gears are cut ' square', as this gives greater strength than helical. Hence a more agricultural change. After a while of course you don't notice it.
Can you please tell me, do the panniers detach?
Thnx
Barnowl is offline
post #5 of 6 (permalink) Old 11-13-2014, 02:06 AM
cannonballs's Avatar
Thnx
i got the voyager but panniers should be the same a couple ao 10 mm bolts hold them on
,dosnt take long to take then off
had to remove to clean up spilt milk when i didnt secure it one trip home
2010 voyager
v/h performance pro pipe with quieter muffer
pcv with ign
individual gear mapping
auto tune
commander 11 rear tyre
2 inch risers
Allycat air intake
cannonballs is offline
post #6 of 6 (permalink) Old 11-13-2014, 12:01 PM Thread Starter
Thnx for all your advice. I am situated in the UK, but I think the spec. is the same world wide.
Barnowl is offline
Nomad issues ? New buyer. Barnowl New Member Introductions 6 11-11-2014 02:15 PM
Ladyhawk on Vulcan 500 needs advice Ladyhawk Vulcan 500 14 08-10-2012 09:56 PM
New member needs advice. smuha0 New Member Introductions 2 12-03-2011 03:31 PM
New Owner needs advice Clint Vulcan 800 2 04-16-2011 12:09 AM
New buyer looking for advice on used Kawi cruisers... Doc_V New Member Introductions 3 04-02-2011 06:57 PM
