Replace Speedo Cable - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 09-28-2009, 05:40 AM Thread Starter
The speedo cable on my 1997 vulcan 500 just snapped. I need to replace it but I have no idea how to.
Anybody can help and tell me how do I replace it?
I know how to remove the tire apart as I have already changed the fork oil and seals not too long ago.
Thanks for any help.
mouka is offline
post #2 of 6 (permalink) Old 09-28-2009, 08:10 AM
justinmccurdy25's Avatar
the best tjing to do is to get a manual online here . you could probly find one for free to download you just have to ask around. it will tell you step by step procedure on that kind of stuff
justinmccurdy25 is offline
post #3 of 6 (permalink) Old 09-28-2009, 08:37 AM Thread Starter
Thanks, I will try doing that.
I just wanted to know form people around here how complicated of a job it is to replace the speedo cable.
My guess is that it's a simple enough job, but I could be totally wrong.
mouka is offline
post #4 of 6 (permalink) Old 09-28-2009, 08:47 PM
I have the following book about kavasaki vulcan 250-500.
It doesn't cover the speedometer replacement surprisingly.
http://www.amazon.com/Kawasaki-454LT...4188587&sr=8-2
I had mine replaced in only 30min-1h by the shop under warranty. So I guess it is fairly easy.
My only concern would be that there is a little piece remaining in the "connector" on the wheel side. It's a sort of little ball that rotates or something. Not sure how you take it out. It was my case.
Otherwise, I am pretty sure it is just "plug and play" once you remove the top panel.
mimizone is offline
post #5 of 6 (permalink) Old 09-28-2009, 08:57 PM Thread Starter
I talked to my local Kawasaki dealer, he ordered the cable for me and said that it's something I can do in 5 minutes flat.
Just unscrew it on both ends, then screw the new cable into place, and you are done.
Best thing is that it only costs $19, including tax.
mouka is offline
post #6 of 6 (permalink) Old 09-30-2009, 08:31 PM
maryes7's Avatar
pretty easy
It is pretty easy. Just unsrew it form the wheel. Look carefully at how it is routed up to the speedometer. It also unscrews from the speedo. To lube just unscrew from the speedo and lubricate.
maryes7 is offline
Can I replace throttle cable without removing tank? Dirtwiz Vulcan 900 12 06-10-2014 09:25 PM
OK, How do i replace the speedo bulb? Zixxer10R Vulcan 1500 3 06-06-2012 09:37 AM
Remove muffler to replace clutch cable? wolfpacker Vulcan 900 10 05-31-2012 07:31 AM
Control line & cable replace / reroute RideInRed Vulcan 900 1 05-14-2012 10:16 PM
99 VN1500 New Speedo Cable XLR8 Bikes For Sale 0 03-10-2008 12:12 PM
