Air Filter Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 05-08-2019, 09:35 AM Thread Starter
Year/Make/Model: 2000/Kawasaki/Vulcan EN500
Question Air Filter Question
My bike will turn over but won't start so I'm checking multiple things. I took out the air filter but am wondering if its missing a part.
There are two photos below.
On the left is a photo of what came out of my bike (the one in color).
On the right is a photo is from the manual which refers to the "air cleaner element" in the top of the photo, then it refers to the "sponge gasket, the plastic holders and wire screen". But... that seems to be all I have.
So am I missing the "air cleaner element"?
Also, people have talked about cleaning the element then soaking it in oil. Can someone explain that to me given the parts that I have (or need to go get)?
Thanks!
Sultan
ID:	228514   Click image for larger version
SultanVulcan is offline
post #2 of 9 (permalink) Old 05-08-2019, 09:51 AM
fastpakr's Avatar
Yep, you're missing a foam piece that should be sandwiched between the screen and the plastic grid over it.
There are some pictures here:
https://www.vulcanforums.com/forums/...ir-filter.html
I don't think the foam is sold separately, but you can replace the whole thing using Kawasaki part number 11013-1250 for about $30 or the K&N version KA-5096 for $62.
'99 Vulcan 500, 29k miles
fastpakr is offline
post #3 of 9 (permalink) Old 05-08-2019, 11:37 AM Thread Starter
Thanks. Is the foam piece the part Iím supposed to soak in oil?
What does that do?
post #4 of 9 (permalink) Old 05-08-2019, 12:43 PM
fastpakr's Avatar
Yes. That's the actual filtration component. The rest is just there to hold it in place (and some gross filtration through the screen).
fastpakr is offline
post #5 of 9 (permalink) Old 05-08-2019, 12:44 PM
fastpakr's Avatar
For what it's worth, it's probably a generic type of foam used for filtering air. If you could source the material, you can probably just cut a piece to fit.
fastpakr is offline
post #6 of 9 (permalink) Old 05-08-2019, 12:58 PM
Tynker's Avatar
Year/Make/Model: 2009 Kawasaki Classic LT
Color: Green & Silver
You can go to Walmart, in the cloth dept. and get a 2' X 2' 1/2 inch sheet of foam. Cut it to fit the item that you have. and soak it on motor oil, and the squeeze, most of the oil out. It should have just a light film of oil on it.
Tynker is offline
post #7 of 9 (permalink) Old 05-08-2019, 01:01 PM
fastpakr's Avatar
1/2" would be too thick for this application. Do they stock thinner options as well?
fastpakr is offline
post #8 of 9 (permalink) Old 05-08-2019, 02:11 PM
Tynker's Avatar
Half inch will work just fine, it will compress, but they do sell thinner foam, if you want.
Tynker is offline
post #9 of 9 (permalink) Old 05-08-2019, 02:33 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
I second the recommendation for the K&N air filter.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 208,000+ miles so far
'98 EN500LTD 'Sioux' 19,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
Air Intake Question - Burning Smell Fear30 Vulcan 650 S 9 01-25-2019 11:26 AM
Question on the air filter VN 1700 ? Dinskoy Vulcan 1700 1 11-29-2018 03:41 AM
Air Filter Question mbinnie Vulcan 1500 2 10-12-2014 05:20 PM
VN1500D air filter conversion blood nut Engine Work 1 08-23-2014 11:54 PM
Custom Kawasaki VN1500 Build Thread raptor660fam Vulcan 1500 117 04-06-2014 09:50 PM
