Weep hole in side of engine leaking coolant - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
  • 1 Post By bikerbill
  • 2 Post By Blaine
post #1 of 6 (permalink) Old 01-15-2019, 04:25 PM Thread Starter
Picture is of the weep hole. It is leaking coolant while the bike is running at a slow, but steady rate. found it when I was checking my oil level one day. Appeared out of no where.
Anyone know what it is? How to fix it? I'm at a loss. I can't find any reference to this hole in any manual or any forum, much less the fact that it's weeping. The hole is on the other side as well, and it's also on stock photos of the EN500 so it's 100% not aftermarket.
Any help is WONDERFUL. Thanks in advance.
Below is a link to the pictures of the hole.
https://imgur.com/a/62VLwnm
EDIT: Bike is an '04 Vulcan 500. 13k miles.
ID:	226520   Click image for larger version
ID:	226522   Click image for larger version
Sunsunsun is offline
post #2 of 6 (permalink) Old 01-15-2019, 08:27 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
Sunsunsun,
That weep hole drains the pocket where the spark plug and boot reside. Also within this pocket is a coolant pipe and hose. Have the valves been adjusted recently? If so then the o-ring on the coolant pipe may be leaking and needs to be replaced. The coolant hose that connects to this pipe is secured by a clamp that could be loose. If it is the o-ring it might seal itself. You may be able to reach the hose clamp from the side. It is behind the spark plug boot.
Hope this helps.
SpinDog likes this.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 208,000+ miles so far
'98 EN500LTD 'Sioux' 19,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
post #3 of 6 (permalink) Old 01-16-2019, 06:16 AM
Blaine's Avatar
The O-Ring is 14mm.
If at first you do succeed,try not to look surprised.
Blaine is online now
post #4 of 6 (permalink) Old 01-16-2019, 07:20 PM Thread Starter
Is it the hose with the arrows on it in the below image?
https://imgur.com/a/0VtXhl8
If not, do you mind taking a picture of the hose you are talking about? This hose isn't visibly leaking.
Thanks in advance,
Jared
post #5 of 6 (permalink) Old 01-17-2019, 06:13 AM
Blaine's Avatar
Thanks in advance,
Jared
It not usually the hose but rather the pipe it connects too...It has a o-ring on the bottom that sits into the head.....The o rings should be replaced every time the valves are adjusted.
bikerbill and SpinDog like this.
post #6 of 6 (permalink) Old 01-17-2019, 06:16 AM
bikerbill's Avatar
Color: Black
Yes, that is the hose. If youíre not seeing a leak at the hose then the leak is likely to be from the o-ring. The o-ring is located where the pipe inserts into the cylinder head and will require removing the fuel tank to remove it to replace the o-ring. How good are your mechanical skills?
'Biker' Bill
Levelland, TX
Engine Guard for VN900, what are these two holes for? (pics included) Vulcaner Vulcan 900 3 11-08-2018 03:42 PM
Coolant not draining? RedHorse Vulcan 800 6 04-22-2018 06:43 PM
Its Leaking From the Engine..Please Help Nightprodigy Vulcan 800 3 05-15-2010 08:38 PM
Engine Coolant STEVEWOOD15000 Vulcan 1600 4 03-15-2010 09:33 PM
Blowing oil from weep hole? 00Robo Oil and Lubrication 0 05-14-2009 10:52 PM
