Another Switched 12v Source - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 08-23-2018, 11:01 AM Thread Starter
hcinciripini's Avatar
Year/Make/Model: 1990 Vulcan 500
Displacement/CC's: 498
Color: Red
I've ordered a tachometer and a phone mount with usb charger...
I didn't want to splice into the factory harness, those squeeze splices may work, but I don't trust them to last.
I didn't wanting to run wires from the tail light all the way up, not too many places to hide it without pulling the harness and using a roll of electric tape/loom to keep it looking clean.
I don't have the know-how/guts to modify the junction box as is shown in the USB charging dock, switch 12V thread, although that would be ideal because switched accessory circuits make sense. If @Pardner anyone has better pictures of where to cut the trace and/or if the en500a1 circuit board is the same, I'd definitely be interested!
Anywho, I found a switched source in the headlight box... the speedometer light! I don't advise pulling many amps from that circuit because I don't know what it's rated for, but it should easily be enough to activate a NO (normally open) relay and allow me to use the existing accessory plugs.
I unpinned the connector on the speedometer side and soldered jumpers onto the flat area and reinstalled them, they were tight but they fit. These are be connected to the energizing circuit of the relay. I connected one side of the contact circuit to the positive accessory port, the other side of the relay is now my switched (+) source that will be used to power the usb charger and what I suppose is the light circuit on the tachometer.
Should I ever need to remove the modification, it's as simple as pulling the pins again and unsoldering the connection.
hcinciripini is offline
post #2 of 4 (permalink) Old 08-23-2018, 09:55 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
That looks good.
The Vulcan 500C from '96-'98 has a dedicated Switched circuit in the headlight bucket *and* under the seat. The fuse is 10A and will run a pair of 35W spotlights with ease. (at least until I added a relay to ease the load on it) I still run some GPSs and LED spot lights thru it.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 208,000+ miles so far
'98 EN500LTD 'Sioux' 19,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
post #3 of 4 (permalink) Old 08-27-2018, 07:30 AM Thread Starter
Color: Red
I'm working with a 1990 en500-a1. Mine are hot regardless of ignition position.
It's kind of a pain, I can't find any online manuals for this model, only available for '96 and up.
post #4 of 4 (permalink) Old 08-28-2018, 05:53 AM
Blaine's Avatar
.....Its actually a 454 LTD.
Kawasaki EN 450 EN 500 454 LTD 500 Vulcan 85 04 - Download service / repair / owner / maintenance manuals, motorcycle tutorials, microfiche
If at first you do succeed,try not to look surprised.
Blaine is offline
?Source for chrome handlebar mount 12v outlet? bigmoe Vulcan 900 12 01-17-2012 11:45 PM
H3 12v 35w to H3 12v 55w????? kettlinton General Vulcan Talk 2 07-19-2011 09:36 AM
Switched wire advice KenDawg Vulcan 900 1 03-11-2011 01:28 PM
Took the plunge, switched to Rotella. silenthill Vulcan 900 48 12-23-2010 10:17 AM
switched power source biker Vulcan 900 0 05-31-2009 08:21 AM
