09 Vulcan 509 LTD battery problem? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 12 (permalink) Old 08-05-2018, 07:20 PM Thread Starter
I wasnít able to ride for a week and when I went out this mornings the started just clicked. I charged the battery and she started up. After a 50 km ride she was starting fine. After lunch I went for another ride. Started right up no problem them 7km down the road she just died. Warning lights would not come on and not clicking from the starter.
After a tow home I checked the battery voltage and it was down to 10.5v. Charged it up again and no start just a click. Battery voltage went down to 2.5v. After setting for a little while it was back up to 13v. I suspect the battery has lost itís capacity. Any thoughts?
Thanks in advance for your help.
Ted
09 Vulcan 500 LTD
Amherstburg, Ontario
Ted Harris is offline
post #2 of 12 (permalink) Old 08-06-2018, 07:25 AM
Venom831's Avatar
Year/Make/Model: 2002 Vulcan 500
Displacement/CC's: 500
Color: Maroon
Are your posts tight?
Sent from my SM-N950U using Tapatalk
'02 Vulcan 500 -
Venom831 is online now
post #3 of 12 (permalink) Old 08-06-2018, 08:23 AM Thread Starter
Yes, I did check that. I charged battery overnight and still no power to the starter. When I boosted from my van she started right up. As soon as I disconnected the boost she died so I am now thinking voltage regulator. Even though the bike is an 09, it only has 5800 miles so I canít believe it would be anything to serious.
post #4 of 12 (permalink) Old 08-06-2018, 09:54 AM
Color: Black / grey
I'd change out battery first - it's easier.
A battery voltage can look good but the power to turn over the starter, the amperage, can be next to none.
You state that after a charge the voltage seems good yet wont start.
Classic battery bad problem.
After a new battery then you can check the charging system.
But with a bad battery you cant be sure of the charging system health.
Venom831 likes this.
vulcandoc is offline
post #5 of 12 (permalink) Old 08-06-2018, 01:08 PM Thread Starter
I changed the battery and started right up. Charging showed 13v at idle. I think it should be around 14v so still thinking voltage regulator.
Ted
09 Vulcan 500 LTD
post #6 of 12 (permalink) Old 08-07-2018, 06:29 AM
Blaine's Avatar
Ted
09 Vulcan 500 LTD
13v is good for idle should come up to around 14.6 when revved up.
If at first you do succeed,try not to look surprised.
Blaine is offline
post #7 of 12 (permalink) Old 08-07-2018, 06:59 AM
Color: Black / grey
Agreed, at idle it will be a lower charge, and at a faster engine speed it will top out about 14.5 volts.
post #8 of 12 (permalink) Old 08-07-2018, 11:18 AM Thread Starter
As soon as I got the battery installed the skies opened up so I havenít had a chance to check but I will.
Thanks to you both for helping out. I appreciate it.
Ted
09 Vulcan 500 LTD
post #9 of 12 (permalink) Old 08-10-2018, 04:02 PM Thread Starter
New battery installed. Everything is good. Thanks guys.
Ted
09 Vulcan 500 LTD
post #10 of 12 (permalink) Old 08-13-2018, 07:07 AM
Color: Black / grey
You already posted new battery but you didnt check if fast idle charging was good.
Battery -- Kawa Vulcan 500 ltd 2007 NeoNine General Vulcan Talk 4 07-03-2014 06:50 AM
New (to me) '09 Vulcan 500 LTD CaAzJayTee New Member Introductions 6 05-05-2012 06:59 PM
Service Manual for the '09 500 LTD. Malaikatoo Vulcan 500 4 05-16-2011 11:31 AM
Windshield for an 09 Vulcan 500 LTD simonsmom Vulcan 500 12 10-12-2010 07:03 PM
09 500 ltd for sell big t Vulcan 500 0 08-18-2010 02:46 PM
